Not yet, but if I get it, will have one tomorrow.... maybe today....
Welcome, here I figured you were already on here all along!
I think it's safe to assume that the 96-97 PCM's will NEVER be supported.
Tom...why don't you swap to an 0411 LS1 PCM?
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
