Page 6 of 26 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 253
Thread: Flashscan data logging..
  1. #51
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Yea.. my bad its a 1g.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  2. #52
    Quote Originally Posted by waterbug1999 View Post
    will this work as good as any other?
    Also, I took the 1meg memory out of my camera and put that in the V2.. Do I need more memory or should I just buy a bigger one and put it in the V2?
    On V2's display, the analog inputs will show voltage only... not AFR...
    But, in the scantool, you will see the AFR (after you select the CALC.AFC_xxx pid).
    This will be ok if you have zero ground offset... otherwise the serial input (using the null-moden adapter between the two cables) is best.
  3. #53
    1GB is plenty.
  4. #54
    Mar 2008
    Thanks.. Im pulling the car out of my storage tomorrow so I will try the V2 data logger and see how it works at the track on Saturday.
  5. #55
    Mar 2008
    well, im in the car now and its says on the V2 "passthru active".. um, now what? How do I load up the different PIDs i want scan / then upload?
  6. #56
    Mar 2008
    did i lose all my stuff?
  7. #57
    You cant have the V7.5 tune or scan tool open when using EFILive Explorer, exit from them and hit refresh in EFILive Explorer.
  8. #58
    Mar 2008
    same shit...
  9. #59
    Mar 2008
    ok.. its all back.. Im sitting in the garage with the V2 in the lab top. How do I pick what PIDs and how to send them into the V2?
    I thought I had to have it hooked up in the car to to do it??
  10. #60
    Mar 2008
    And where do you find the PIDs? Alls I see are the descriptions in the EE under documentation.
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
