Page 7 of 26 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 253
Thread: Flashscan data logging..
  1. #61
    Do you see the Options.ini file under either of these places:
    C:\Program Files\EFILive\V8.1\Programs
    C:\Program Files\EFILive\V8.1\Config
    Drag the Options.ini from the upper pane (one of those 2 folders) to to lower pane (Config Files tab).
    Once you have done that you are ready to log (disconnect laptop, restart V2, on V2 select the PCM that is for your WS6 (LS1B_A for A4, LS1B_M for M6).
    PM your phone #.
  2. #62
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    I believe its all read done.. i just dont understand how to get it to the V2.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  3. #63
    Mar 2008
    Here ya go..
  4. #64
    Mar 2008
    here ya go..
  5. #65
    Jody,
    Save the contents of the .zip and drag it to the Config Files tab under EE.
    This Options.ini has 5 example pid lists for LS1B_A (LS1B = 1999+ LS1, A = A4).
    When you goto "Select PIDs" on the V2 menu, you will see those 5 pid lists.
  6. #66
    Mar 2008
    You are the man!!! Thanks a bunch!
  7. #67
    To do serial AFR logging from the LC-1, see this pic:
    You need to join those 2 cables using the null-modem adapter shown, or you can buy an LC-1 serial cable from TAQuickness;
    The stereo jack plugs into the LC-1's SERIAL OUT cable.
    This will allow you to display the wideband AFR as a pid on your V2 LCD.
  8. #68
    Mar 2008
    I have a wideband in the car so I can see the AF... But, I think you said it will just show Volts correct? But, once uploaded, it will turn into AF on the efilive "tune"?
  9. #69
    If your wideband is connected to V2 via analog (LC-1 brown signal wire, white/green ground wire), then you will only see the voltage on the V2 LCD (you will see the AFR when you view using the ScanTool).
  10. #70
    Default Display of analog AFR on V2...
    Hmmm.... maybe I can edit this into the Options.ini file...
    Do you use the pid CALC.AFR_LC11...?
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
