Results 1 to 4 of 4
Thread: Strange log file problem
    Feb 2007
    Default Strange log file problem
    I recently started having a problem since upgrading to the most up to date version of EFILive. I am having the problem with logs I make on the black box and on the desktop. I am attaching a couple of pics to show the problem. The logs may open fine or they may have this problem. It's kind of intermittent. I am running Vista on my laptop, but a friend of mine is running XP and he said he's having the same problem.
Name:	log file problem 2.jpg
Name:	log file problem 3.jpg
    swingtan
    Guest
    Hi Josh,
    This is the "screen full of notes" problem that has been seen a few times.
    I can reproduce this at will by having a "VNC Viewer" window running when I open a new log file. VNC Viewer is a open-source remote desktop application and not part of EFILive. I can sometimes get the problem to occur with other applications as well and once it seemed to be related to having the Tune tool open in the background ( though I can't confirm this one ).
    To enable you to open the log file cleanly, have a look at what other applications are running. Shut them down one at a time, attempting to open the log file after each one. Eventually you should get a clean opening of the file, then note which application was the one that you close last. It's possible that this was the one causing an issue.
    Personally I think it's got something to do with how other applications and EFILive hook into certain video drivers. But the support guys will know a lot more about it than me......
    Simon
    Feb 2007
    Thanks for the advice, Simon. I'll take a look at that next time I have the laptop out.
    Feb 2007
    Well, curiosity got the best of me, and I had to go grab the laptop out of the truck. Looks like it was an Open Office process running in the background causing my problem. Thank you for the help.
  1. strange acting T42 4L60E combo with 4wd tun file
    By harascho in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 11th, 2011, 02:51 AM
  2. strange file
    By odd boy in forum Gen IV V8 Specific
    Last Post: April 8th, 2009, 10:31 PM
  3. Very strange problem
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2009, 12:37 PM
  4. Strange Problem with COS Setup
    By LSRacing in forum Custom Operating Systems
    Last Post: March 19th, 2009, 10:10 AM
  5. strange idle problem
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 10:31 AM
