Results 1 to 8 of 8
Thread: Black Box "Scanning" only shows Metric
    Default Black Box "Scanning" only shows Metric
    Ive been messing with the black box logging a lil..
    i cant seem to find anything except in Options.ini where it shows the custom PIDs how to change the viewing from Metric to Imperial.
    But i cant get it to work.
    Tryin to read through all these threads, but its getting tiring with a slow internet connection.
    Can somebody please shed some light on this..
    Thanks!!!
    Jonathan
    gets kinda old tryin to converter C to F goin down the road.. haha
    Looks like i should have read for just a few more mintues...
    Found this...
    Post #15? Joecar mentioned the new updates.
    Goin to DL them and see what happens..
    Ok the newest update fixed this issue...
    Now how do i watch the MAP in kPa? instead of psi?
    Press the button "OK"... this toggles.
    Ooops... my mistake... ...I meant press the "Enter" button.
    HAHA, thanks man!!
    pressing Enter just changes the One parameter?
    No, it changes between "normal" units and "alternate" units all the pids that are mentioned at the bottom of the Options.ini or Options.txt file...
    If you don't want a pid to change units, delete it from the alternate units section at the bottom of the Options.txt/Options.ini file.
    Paste your Options.ini/Options.txt file here in this thread.
    haha, i think i know what i did wrong.. i deleted the Manifold pressure Custom PID at the bottom and forgot to copy it to my V2...
  1. what table controls start up decay speed? "how fast it decays out"
    Last Post: March 20th, 2009, 12:10 AM
  2. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  3. Scanning in dashboard "B"
    By Whippled 496 in forum General
    Last Post: September 28th, 2006, 11:38 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
