Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 124
Thread: E38 VVE Setup Guide
  1. #21
    If all goes well with this Saturday's 6 million dollar Lotto dray, it will be first thing Sunday
    I'm waiting to win Lotto too, only problem is I don't enter it
    I also can't justify spending HSV kind of money on something I'd only drive once a week at best (I must be getting old), mind you, I'd happily stare at a new Z06 in the garage any day.
  2. #22
    Oct 2004
    So my odds are only marginally better than yours then LOL
    Andrew
    EFILive Crew
  3. #23
    I'll find an excuse to drive it everyday...
  4. #24
    Member JAY4SPEED's Avatar
    Mar 2007
    On page 3 under "Set Command AFRs",
    The setting for "Parameter: B0146 Set all cells over 80' to 1.00". Does the 80' refer to the intake valve temp axis or does it refer to the kpa axis? If it is referring to the intake valve temp axis and 80' (or 80*) is that in Celsius or Fahrenheit?
    I think the way I read it in my case (I view temps in Imperial) is set every cell over 176*F IVT to 1.00. Would that be correct?
    Or could I change the complete table to 1.00 since I won't be using E80 fuel during my Auto VVE process? It refered to using this table after the E80 blending has been calculated. But, I'm sure I don't understand that table correctly.
  5. #25
    swingtan
    Guest
    b0146 deals with IVT and MAP, so the 80' refers to IVT. And yes, it's Celsius, but you can substitute a value that is just under the normal operating temp of the car. That way you can ensure that this table won't change the commanded AFR's at unexpected times.
    The table its self has nothing to do with Ethanol based fuels. It's the final correction factor to the OL fuel calculations after all other calculations have been done ( including the ethanol calculations ). What this table will do is allow you to alter the OL commanded fuel depending on both IVT and MAP. It can be very useful if used correctly.
    Simon.
  6. #26
    Mar 2007
    I didn't think I understood that table correctly, but I do now. Simon, thanks for taking the time to do the tutorial for us who need step by step help.
  7. #27
    Senior Member alian's Avatar
    Jun 2008
    Simon.
    Nice work Simon, Your work helps so many.
    Many Thanks Ian
  8. #28
    Dec 2007
    Excellent and extremely well thought out document. Very generous of you to share the many hours of work you and your collaborators put into the knowledge to create such and informative source of information for VVE tuning.
    Cheers.
  9. #29
    swingtan
    Guest
    Hi Guys,
    Thanks for the kind words and I'm glad a few are finding this useful. I've made another update to the guide......
    To help with dialing in the VVE, there is now a section on calibrating the base injector flow rate with IAT. Many will know that as IAT goes up, the AFR's can tend to lean out, so you need to add more fuel to correct for this. the new section describes one method to help set up B1213, resulting in stable AFR's for all IAT's.
    Simon.
  10. #30
    Dec 2007
    Hi Guys,
    Simon.
    Thanks again Simon. Excellent work.
    Interesting that Holden never bothered with B1213. Maybe it just fell outside of the ADR drive cycle and was not a priority for them. Chevy certainly looked at it a little, but not as comprehensive as your work.
    Any effect on drivability/throttle response/smoothness?
    Cheers.
  1. E38 / E67 VATS disable guide
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: March 22nd, 2023, 01:35 PM
  2. Tuning Beginners Guide
    By NASABlue in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 02:37 AM
  3. Beginners guide to tuning
    By ringram in forum Tutorials
    Last Post: June 17th, 2006, 10:46 PM
  4. Draft LC-1 Guide
    By 98WS6_JPM in forum General
    Last Post: May 12th, 2006, 02:53 AM
  5. PCM tuning guide
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2004, 05:42 AM
