Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: BB logging pids
    Feb 2008
    The offset is 3.200000E1 which means 3.200000x10^1 which is 32... (En notation means "multiply by 10^n").
    Ok that makes sense now lol.
    The identifiers after the PSL are the positions in the list of pid lists...
    In the attached Options.txt you will see:
    - the first PSL lists PSL_01 and PSL_02 -> these are rows 1 and 2 in the pid selection list ("LS1A_M" and "LS1A_A");
    - the second PSL lists PSL_03 and PSL_04 -> these are rows 3 and 4 ("LS1B_M" and "LS1B_A");
    and so on...
    a PSL may be used by 0 or more pid list positions.
    See the comment:
    Code:
    ; _________________________________________________________________________
    ; PID Selection List
    ; *Section_Names is a comma separated list of indexes from the initial *PID_SELECTIONS section above.
    ;        The XX in PSL_XX matches the entry number in *PID_SECLTEIONS
    Ahhhhh, I see now. so whatever PSL## is listed on the PID selection, it kinda picks up the lines (i assume) of the text file in order, yes no?
    Thanks, still a little fuzzy but I got the idea now.
    12 Second LMM
    lol......is this what we're trying to say...?
    Nov 2006
    there needs to be a tutorial for BBL and V2 or,
    make the options.txt easier to understand for noobs.
    i`m glad i`ve had my V2 since `06 Nov. even so there is still a lot
    of things that i don`t know about, and how to use.
    like where are the RR filters stored and can they be combined.
    LC-1 WBO2
    Sep 2008
    I have an '03 LB7, is there a PID in the options.txt file that does the calculated boost pressure??
    Also, is there a way to create custom calculated PID's for use with BBL?
  1. logging pids
    By aaronr in forum Black Box Logging
    Last Post: February 18th, 2009, 11:46 AM
  2. Issues logging E38 PIDS
    By thunder550 in forum FlashScan V2 BB Logging
    Last Post: April 28th, 2008, 05:52 PM
  3. More PIDs in E67 for BB logging?
    By scdyne in forum Black Box Logging
    Last Post: January 30th, 2008, 12:22 PM
  4. Logging E38 Specific PIDS W 08 Z06
    By 02Z06 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 13th, 2007, 12:04 AM
  5. Best PIDs for Logging Dry Shots?
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 23rd, 2006, 06:28 AM
