Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Mini laptop for tuning with EFI Live?
    May 2007
    Default Mini laptop for tuning with EFI Live?
    http://www.walmart.com/catalog/produ...ct_id=10575194
    I am looking for a laptop for tuning only. I was thinking this is small and compact but is it to small and compact?
    Does it even have what is needed for EFI Live?
    Any help would be great , thanks Chad.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    Oct 2004
    Looks like it should be fine - I assume it is running a regular i368 port of XP.
    Andrew
    EFILive Crew
    That one is good, other forum members are using that one.
    Oct 2006
    2006 Trailblazer
    Lifetime Member Aloicious's Avatar
    Nov 2007
    I use one of these:
    http://www.dell.com/content/products...dhs&ref=homepg
    works great for tuning, mine's slightly modified but it still worked great when it was stock.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    May 2007
    Quote Originally Posted by Aloicious View Post
    I use one of these:
    thanks to all of you. This Dell that you are using, is it the cheaper of the 3? It doesn't say if it is using windows xp like the middle one.
    2000 NBM trans am.
    May 2007
    I read a little more, I like the middle option of that Dell. Thanks guy's.
    2000 NBM trans am.
    Any Netbook running Win XP can run EFILive no problem, right now the HP uses a Via C7 processor but the Acer/Asus/Dells use the Intel Atom. All are x86 processors. I want one for taking notes in class, my 17" HP laptop weighs 8lbs and is a bit much to take to classes with small desks.
    Quote Originally Posted by Aint Skeered View Post
    If you like the Dell, get it with 1GB DDR2 (add $25) and 16GB SSD (add $40).
    May 2007
    I like it more for the longer battery life.
    2000 NBM trans am.
  1. running efi live on a mac laptop
    By dmaxpower in forum General (Diesel)
    Last Post: March 25th, 2010, 01:02 PM
  2. Tuning without a laptop
    By mavdog32 in forum General
    Last Post: January 12th, 2010, 12:04 AM
  3. Virtual PCM Tuning on Laptop
    By neil in forum General (Petrol, Gas, Ethanol)
    Last Post: May 5th, 2008, 07:19 AM
  4. V1 tuning w/o laptop?
    By ALLslowNOshow in forum Gen III V8 Specific
    Last Post: February 13th, 2008, 01:55 PM
