I am not understanding something correctly about my RR.
When I have it plugged into the vehicle and running, it says Emulation mode. I can switch to real time, and RTACS works for me perfectly.
The one thing I cannot figure out is Flash mode. I switch to flash mode with the vehicle off, try to start, and no go (although it cranks fuel, it seems for some reason the coil does not fire). Back to Emulation mode and it goes first try. Although it did sputter once so I felt it was flooding fuel on the Flash mode start tries.
I've tried programming a program while in Flash mode and have been unsuccessful. Does the RR store one .tun file at a time and uses both for Emulation and Flash? Or does the RR store 2 separate .tun files and you can switch between them depending on whether you are using Flash or Emulation?
If the RR only stores 1 .tun file, why does my vehicle not start when I put it on Flash mode? Is it possible I have an early RR and mine does not have a flash chip? How do I check? My RR is almost 2 years old.
Eric
