Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: help kr* problem
  1. #21
    Try say 5 degrees from the general area in B5913 where KR is happening (see how DYNCYLAIR_DMA and RPM index into B5913)... it is a trial and error "emprical" process...
    or shift (by copy/paste) your whole table upward (if I'm thinking right) to reduce timing (since the load has decreased).
  2. #22
    Mar 2008
    dam bro i would hate to mess something up,im fearlly new at tunning could you give me a hand?
  3. #23
    Ok, I took newtune_for_trans0003.tun above and tweaked it a little...
    I reduced your B5913 and B5914 a little... try this and see what happens... if it still knocks then it may be due to mechanical reasons (something hitting, clunking, loose, broken)... if knock persists then just go back to your 0003 timing tables.
    I also did:
    - fixed the OOR values like you did in your current tune,
    - set the throttle kickdown tables to 100% like you did in your current tune,
    - moved the WOT downshift points below the WOT upshifts,
    - moved the TCC release curves down a little.
    If you load the 1004 file, and load the 0003 file as the alternate tune, you can then compare the two to see what I did.
  4. #24
    Mar 2008
    I also did:
    thanks bro i will load that tune tomorrow cause im verry sick and its cold out side.......im seeing 8lb of boost
  5. #25
    Hope you get feeling better soon...
  6. #26
    Mar 2008
    hey bro i tried your tune and i was still getting kr,i spend all day yesterday inspecting the truck and did not find anything wrong.so what i did was desensitize the knock sensors a little on b6235,b6244,b6250,b6255 and knock is gone....i was only seeing knock in roll wot runs when it would down shift,but when i would go wot from a dead stop no knock...........thanks for your help joecar and thanks for adjusting my trans shifts and tcc release truck feels alot better
  1. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
