Very good read,
and good info here:
http://www.gofastnews.com/board/tech...-monitors.html
Very good read,
and good info here:
Post #9
Basically Bosch O2`s are inaccurate out of the box, if true how would Bosch be able to sell any?
Also he`s had good luck with Tech Edge controllers, that work with Bosch LSU sensors.
"If you are seriously into tuning, look into a multi-gas analyzer.
The Bridge Analyzer that I found was $3,299.00.
I`ll go ahead and trust my LC1 with the Bosch sensor because I am not "seriously into tuning" anyways.
Why compare a gas analyzer to a WBO2 when the OP asked for a WBO2?
I know he said Air-Fuel Ratio Monitor, but it was apparent what he meant.
LC-1 WBO2
Has anyone tried the Powerdex AFR Monitor made by NGK?
I've had two of the PLX Devices M-300's now and both of the contollers have quit on me. I need something that doesn't look like it's made from cheap material and has some quality and durability put into the design and assembly.
And of course will work okay with EFI-L.
It does not have serial connection, only analog.
Read this.
Air-Fuel Meter Shootout.pdf
LC-1 WBO2
I was gobsmacked after reading this.
That is a very valuable piece of information. I think it is "stickyable", especially for relative newcomers like myself not really knowing what to buy when starting out tuning. It just shows you that if you get the wrong kit how hard it may be to get your motor dialled in properly.
Luckily I bought the LC-1, but only because it was offered to me by the same guy I bought my V2 from. He obviously had done his homework.
2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
"An Old Dog learning new tricks"
I use a Tech Edge 2J1 and also now run an LA1 gauge via a serial splitter. When comparing the TE to a commercial unit on a dyno, the results are very close. The LA1 gauge is actually a lot easier to read than the V2 and due to the analogue scale, is able to display spikes better than the V2. here's a short video of the LA1 and the V2 working together.
http://www.youtube.com/watch?v=WCDSMmRMtTM
Sid, the TE 2J1 unit is designed to be permanently mounted in an engine bay, so is a fairly rugged unit. It has both serial and analogue outputs, the analogue signal is possibly more accurate than others due to it being ground referenced to the V2. Many other "low cost" units do not ground reference their analogue signals, leaving them susceptible to drift.
Simon.
I'm considering getting a Tech Edge. The LA1 gauge looks neat though.
FLASHSCAN V2 & AUTOCAL
