Can anyone tell me where I can get some info on what is available(if anything), computer tune's, chip's, or anything really(mechanical or electrical *more power*)...e.t.c. for a 1996 H1 Hummer Turbo Diesel 6.5 non-intercooled.
Thanks in Advance...
FLASHSCAN V2 & AUTOCAL
Link to a website maybe? Or someone on this forum has worked with one before...
Try over at dieselplace forum. They have a section on 6.5 that seems to be pretty popular.
Will give it a shot.
Thanks mxracer
Here is a list to find good stuff.
I would say call Heath and talk to him and he will set you up.
If you look any of them up in google you will find the sites.
Heath Diesel
Kennedy Diesel
SSDiesel Supply
2008 2500HD 4X4 LTZ Z71 6.6L LMM
Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
Things still need to put in: PCV Re-Route,Air Dog AD-200.
your going to have tune the pcm the old school way.
you will need these items.
http://www.moates.net/product_info.p...roducts_id=137
http://www.moates.net/product_info.p...roducts_id=138
and depending on the chip one of these
http://www.moates.net/index.php?cPath=51
Tunerpro software can be used with the right definition and XDF files.
Some of the 6.5td used a PMD that controlled some of the injection pump and can have a effect on power with the right mod. I believe the 96 you have may have a pcm that you can burn a chip for. Dont expect a ton of power, I think max might be around 75hp gain.
Heres a link to some info on burning chips
http://www.moates.net/documentation.php
I have often though about burning chips but I dont have vehicles that are OBDI or early OBDII around and no one ask me to do chip burning so I dont plan to get involved with that.
Hope this helps.
I thought 6.5 software was in the development stages with EFI live...did something change?
That would be awesome!!!
