Results 1 to 10 of 14
Thread: rich AFR at WOT
    Apr 2008
    Default rich AFR at WOT
    Hi,
    When I attached LM1 WB to Commodore 08 yesterday and then I tested the car @ WOT, the car was too rich starts with 11.xxx and ends with 10.xxx. Then I tuned the car, I needed to command 14.8 - 13.8 in order to get what I need at the 3rd gear!!!! Is that normal!!!!
    Even after tuning it, the car was rich in the 1st & 2nd gear (11.5 - 12), but when it shifts to 3rd it starts getting close to the command PE. Any idea??
    Regards,
    Odd Boy
    Mar 2007
    Someone had a problem with this recently in their truck and someone else posted to change the COT (Cat Over Temp?) tables. Take a look there and let us know!
    Apr 2008
    I've already done it, but no difference. by the way, I am the one who intiated that one.
    Regards,
    Odd Boy
    Apr 2008
    where r u
    Regards,
    Odd Boy
    Oct 2005
    Dude thats a shocking way to tune.
    It might kind of work, but it sucks. <removed comment>
    Do your VVE properly seeing as you have a wideband.
    Then when its all done right it will fuel right.
    Last edited by joecar; March 14th, 2009 at 06:57 AM. Reason: Funny but in bad taste... (sorry Richard)
    2008 Z06 C6 Corvette
    Oddboy.
    If you are running an MAF tune it and the VE's. The MAF controls WOT PE. When it's right at WOT then PE commanded will match, closely, your measured AFR. The VE's in this case don't have to be perfect, just close.
    If no MAF then do the VE's for commanded to match actual. However when the weather changes actual will also..
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    1/8th mi-1.526-60'-6.862-1/[email protected]
    Apr 2008
    Quote Originally Posted by ringram View Post
    It might kind of work, but it sucks. Its like feltching a dog if you are hungry.
    what is VVE? Is it the volumetric efficiency
    Quote Originally Posted by jfpilla View Post
    Oddboy.
    Joe
    I am running maf, what shall I do here
    Regards,
    Odd Boy
    Aug 2008
    Virtual Volumetric efficiency
    There are a couple of tutorial's I think...
    FLASHSCAN V2 & AUTOCAL
    Nov 2006
    Quote Originally Posted by odd boy View Post
    VVE = Virtual VE
    I think the suggestion about the Cat Over Temp tables was reference to
    turning them off like when doing Auto VE.
    This comment is epic and should be used to describe using <removed name>.
    Last edited by joecar; March 14th, 2009 at 06:56 AM. Reason: Slandering the competition, they can't take it (sorry mr.prick)
    LC-1 WBO2
    Mar 2007
    I remember way back when reading on the Supra board that people talked about AFR not being constant in each gear. I'm not sure if this is correct or common and if it can even be tuned around without having a separate fueling for each gear.
    Since your highest load will be in third gear (you usually never rev all the way out in fourth), I wonder if people just tune for third gear so the motor is safe and you deal with 1st and 2nd? I'm not sure really and this post is a definite learning experience for me.
    Following along hoping to learn...
  1. too rich?
    By eclispe1 in forum Custom Operating Systems
    Last Post: March 10th, 2009, 04:57 PM
  2. Rich decel...still...also..etc
    Last Post: March 7th, 2009, 04:39 AM
  3. Idle is rich
    By zapp168 in forum Gen III V8 Specific
    Last Post: August 14th, 2007, 10:29 AM
  4. I'm too Rich!!
    By tgeers in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2006, 03:52 PM
  5. WOT afr too rich
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2005, 06:08 PM
