Results 1 to 7 of 7
Thread: Wouldn't it be easier to tune with PE mode deleted/disabled?
    Mar 2009
    Default Wouldn't it be easier to tune with PE mode deleted/disabled?
    Since I don't have EFI Live in my posession and can't seem to get a stock L31 tune, I'm left studying the LS1 tune provided with the demo. Why is there a PE mode in the first place? Why not just put in the desired value in the "Commanded Fuel when in open loop (normal)"? The only way to have 100kPa at 5,000 RPM's is to be at WOT anyway, why have 2 tables to come to this conclusion?
    Nov 2006
    Do you want to command 14.63AFR @ 5000RPM and 20kPa MAP?
    LC-1 WBO2
    Mar 2009
    Aww, my stupid ass missed the fact that that table is ECT vs. MAP and not RPM vs. MAP.
    Nov 2006
    Give yourself a credit for catching my retort.
    There's always the COS option. {B3647}
    LC-1 WBO2
    Mar 2009
    Well it's not that I've never tuned before, I've just never tuned anything this complicated. I've tuned an SAFC, SDS, and tweaked on an Apexi Power FC which is all child's play compared to this.
    Even with a COS, consider this:
    B3616 PE Enable is based on TP...
    B3647 AFR is based on MAP...
    MAP lags behind TP (you snap TP open, MAP then follows after some very short delay).
    B3618 provides that initial "pump" shot.
    For tuning, I set B3618 flat across at say EQ 1.17, and the last 3 columns of B3647 to the same value.
    Mar 2009
    I'm also wondering where's the intermediate pump shot? All there is is a no delay PE mode that dumps only when you give it 90%? There has to be a pump shot below that or the thing would stumble badly off the line. I also can't find the PE timing adder. Or is that the fuel mixture spark correction table? My feeble brain can't comprehend another use for it.
  1. EGR not disabled
    Last Post: January 19th, 2010, 05:11 PM
  2. Anyone fully disabled Pilots?
    Last Post: May 1st, 2009, 04:37 PM
  3. Injector Question: Some easier to tune than others?
    By Goldfinger911 in forum Gen III V8 Specific
    Last Post: September 20th, 2007, 08:11 AM
  4. How Do I Enable IAT with MAF Disabled?
    Last Post: May 14th, 2006, 07:34 AM
  5. DTC won't stay deleted.
    By curtbriggs in forum General
    Last Post: February 6th, 2005, 08:06 AM
