Results 11 to 20 of 21
Thread: RAFIG on 2002 Z06
    What OS and engine calibration id's do you all have...?
    OS: 12221588
    OS ID: AC
    Cal: 12577176
    BCC: YCJR
    Everything you might want to know.
    Don't mean to offend, but jic, all are being selected at one time?
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Nov 2007
    I have the COS3 now. I don't remember what the original was off the top of my head. But I know it was from an 03 Z06 bucause of the column lock issue.
    02 Z06, 573/530rw N/A 416, 10.21@136.12.
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    I was corrected by the owner of the car. Its a 2003 C5Z.
    OS: 12593358
    Cal: 12580402
    Aug 2007
    I uninstalled my EFI Live software, reinstalled and updated to the newest versions. The short term adn long term idle trims still show up as unsupported on this 2003 Z06.
    I've tried to validate the PIDs many times, and it never helps. Any thoughts?
    Mar 2008
    i was having that issue with my stock 02 OS...changed to another 02Z06 operating system and it fixed the problem...same os as jfpilla....dc_justin helped me find this out (hes a efilive instructor)
    Jul 2003
    Dito.. change the OS.
    Aug 2007
    Interesting. I listed my OS a few posts up in post # 14. What OS should I change to? What about if I change the the appropiate COS, will that work? Or should I change to a different stock OS first, then change from that to the COS? Thanks for the help so far guys!
  9. #19
    If you have the 512KB PCM then you could try 12212156 from a 2002 M6 F-car, if you haven't already...
    I seem to remember tho that you have the 1MB PCM...?
  10. #20
    Aug 2007
    Joe, this is not for my personal car, its for a friends car that has a 2003 Corvette Z06. Is the OS you listed compatible with the stock 2003 Z06 PCM?
  1. Can't RAFIG
    By macca_779 in forum General
    Last Post: April 17th, 2008, 03:38 PM
  2. help with RAFIG
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 25th, 2008, 12:02 PM
  3. Rafig Help
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: December 6th, 2007, 04:23 PM
  4. Rafig
    Last Post: November 25th, 2007, 07:39 AM
  5. RAFIG (am I doing this right?)
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 23rd, 2007, 05:47 AM
