Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: Problems reflashing due to something bad
  1. #31
    Sep 2008
    This is getting ridiculous.
    Sorry if Im coming off pi$$ed off, Im not just frustrated because I know the tunes Ive sent ya will work, they do in my 02. And this weeks been hectic as anything...the joys of college right?
    My thoughts Exactly! Thats alright, im more piss off on why the efilive keeps changing the pcm configurations.
    Are you saying that these 2 are the before/after of a flash...?
    Yes, and I have done them many times. When Erik and I were discussin about the difference in the OS, I used the old OS and the fans started to work but the efilive still changes the tune configuration.
    I just recently got 4.10 installed from 3.73 and the efilive keeps changing from 4.10 to 3.73 after everytime I flash. I heard this werid rear noise that has something to do w/ the gear ratio. It slow from stop or on the city but when shift on higher gear (ex. in the highways) its fast.
    BTW, It feels like the gear shifts to higher gear too early, which makes a bad start from stop.
    2002 4.2L I6 Trailblazer LTZ
  2. #32
    Sep 2008
  3. #33
    Default Sanity check...
    When you change OS, do you do a full-flash...?
  4. #34
    Sep 2008
    I had two different tunes from two different companies, both have different OS on my tunes. From pcmforless the os reads 12575262 and for wait4me it has 12587430. From wait4me I ask for pcm modifications so i dont know if changing the os has anything to do with it.
    what is a full-flash? I do the same flash that I have been doing since I got the efilive.
    Here's what I did, upload the tune, click on the green arrow pcm picture, Un-check the fast speed box, check status, start (while keys are on on), turn the keys towards off when told to, tune done, check the tune after the flash and the flash made changes that I did not authorize.
  5. #35
    There are 2 flash functions:
    - cal-only-flash (narrow red down arrow button): used for flashing in calibrations only.
    - full-flash (wide red down arrow button): used for flashing OS and calibrations (i.e. the full file).
    A "calibration" is defined as the collection of tables and parameters containing the operating values for a subsystem (e.g. engine cal, engine diag cal, trans cal, trans diag cal, speedo cal).
    An OS (operating system) is defined as containing the operating "algorithm" which reads the calibrations and uses their values in its algorithms to operate all the subsystems.
    You use cal-only-flash after you have edited some tables/parameters to flash in the calibrations.
    You use full-flash to change the OS (this flashes in the full file including the OS and the calibrations included in that file).
  6. #36
    joecar, P10s cant full flash, everything is done cal only flashes. So to get around it, have to copy all tables from a different tune file over to a stock file.
    goldbergv95, I have been trying to get you to do this because this is your problem right here, you cannot flash a file with a different calibration and you MUST copy ALL the tables over to a stock file.
    Post up the last file that works and the one you want to work, Ill take a look and see what your problem is. As far as i can tell this is NOT an EFILive issue as the OS doesnt just magically change and every P10 Ive flashed Ive made work with no problems (except for the 3 tables in OS 12587430).
  7. #37
    Sep 2008
    Yeah I know, I just changed back to the old os and its still the same, only the fans work but the calibrations still changed.
    Here is the file I used today that changed automaticly usintg the old OS
    After The Tune 2nd Time.tun
    Here were the two tunes that did work but no longer work, have gear shift problems from stop to go and still have torque converter locking and unlock too early. To tell you the truth these two tune from both different companies shift real bad. I think it might have something to do with the 93 tune shift.
    Wait4metuneOldOS.tun
    Modified Today.tun
  8. #38
    joecar, P10s cant full flash, everything is done cal only flashes. So to get around it, have to copy all tables from a different tune file over to a stock file...
    Oh/Ah... I see...
  9. #39
    Sep 2008
  10. #40
    Sep 2008
  1. PCM Options for reflashing...
    By Behold in forum General
    Last Post: May 11th, 2010, 02:24 AM
  2. Reflashing ecu
    By c55asleep in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 5th, 2009, 11:17 AM
  3. reflashing the e67
    By nycblazer in forum Gen IV V8 Specific
    Last Post: April 17th, 2008, 11:10 AM
  4. Reflashing a different year O.S. in?
    By XLR8NSS in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2005, 06:18 AM
  5. Reflashing BCM?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2004, 08:28 AM
Tags for this Thread
