Thread: my box will only shift 1st and 2nd
    Apr 2009
    Default my box will only shift 1st and 2nd
    I have had a uprated box fitted to my holden maloo vortech supercharged
    with a maf less tune and a higher stall
    was driving today normally and all the sudden it will not engage 3rd gear
    has it broken or has it go to safe mode
    thanks steve
    Steve, welcome to the forum...
    Have you check your fluid level/condition...?
    Any DTC's...?
    Apr 2009
    all fine fluids and no warnings on the display
    im runnunig a 3500 fuddle stall
    on a built gearbox
    mafless tune
    bringing up a slightly old thread. my old man's vu has the same problem, but on 2 different gearbox's.
    Im going out shortly to see if there any faults and to see if efilive can make it shift into r3rd or 4th, both times the car has only been driven sedatly along.
    Senior Member MyM8V8's Avatar
    Aug 2008
    Just nosey really, what did you find mate??
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    not much at this stage. the box that's in it now slams into drive,rev out of park. so box is pretty much fubar'd. seems to start in 2nd gear now aswell.
    my old man is just waiting on the original box to come back from auto rebuilder.
  1. 4L60 and shift kit
    By SRT10KLLR in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 21st, 2013, 12:13 AM
  2. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  3. WOT Shift, 1-2, 2-3
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 25th, 2008, 01:24 PM
  4. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
  5. TCM shift points
    By lakingslayer in forum General (Diesel)
    Last Post: March 28th, 2007, 11:09 AM
