Results 1 to 10 of 13
Thread: Bootloader rejected
    Apr 2009
    Default Bootloader rejected
    very green to efi live, but was trying to switch tunes and while communicating with the truck, the laptop would tell me bootloader rejected, try again in 15 seconds and try to turn off high speed. A little lost at this point, any help would be great. The truck is a six speed manual LLY with a clutch and exhaust. Any help would be great thanks in advanced. Dan
    Did you have the radio fuse in? or was the door opened, anything that could cause anything elctrical to turn on/off?
    -Nemo
    2004.5 LLY Duramax, Compounds, EFILive, EvolvedMS.com 50" Trac Bars, DDP Injectors, PPE Pump, 4" turbo back exhaust, 6" Chrome Stack,
    ATS Trans w/ Triple Loc.
    Evolved M.S, LLC & SS Diesel Tuning
    Apr 2009
    The fuse is in, and the only light that was on was the brake light on the dash.
    When i load tunes I have to unplug my radio fuse, turn all lights off, my aftermarket amp unplugged, and somtimes I need to hook a battery charger up also.
    -Nemo
    Apr 2009
    Just thought about it, when i turn the ignition off i pull the key out and that will mess with the lights because its a manual truck. I'll try to just turn it off and not pull the key out. Thanks Nemo!
    Apr 2009
    OK will try the fuse thing! Thanks again
    Let us know what happens...
    -Nemo
    Apr 2009
    Pulled the fuse, never took the key out just turned it off and everything worked great! Thanks again Nemo!
    Good deal, enjoy.
    -Nemo
    Yes, the idea is to prevent other modules chattering on the serial bus during flashing.
  1. bootloader rejected
    By relentless addiction in forum Duramax LLY
    Last Post: May 25th, 2010, 07:26 PM
  2. ls3 bootloader rejected
    By rubbersidedown in forum Gen IV V8 Specific
    Last Post: April 13th, 2010, 11:21 AM
  3. bootloader rejected
    By dmax687 in forum Duramax LLY
    Last Post: November 8th, 2008, 12:43 AM
  4. bootloader rejected PCM locked
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: July 30th, 2008, 10:16 AM
  5. Bootloader Rejected
    By KWSUNDELL in forum Duramax LLY
    Last Post: October 21st, 2007, 08:32 PM
