Results 1 to 5 of 5
Thread: Correct injectors fixed my issues
    Jan 2007
    Default Correct injectors fixed my issues
    Have to say....I'm very happy now with my tune.
    Yeah...of course I'll never be 100% happy...but that's the OCD speaking.
    Jon at FIC (Fuel Injector Connection) hooked me up with a set of LS1 injectors resized to 36lb/hr @ 58Psi.
    I'd been running the Bosch 42lb/hr (@ 39.15Psi) 'Greentop' injectors and had many issues...some of which I had no idea were injector/fuel related.
    Some time ago, as I'd blown my trans and diff I decided to make alot of changes all at once to the Burb (yeah...can be a nightmare but it's my daily driver so I didn't want it off the road for too long).
    I imported, rebuilt and installed a 4L80E trans with Transgo shift kit. Installed a Trutrac/Eaton LSD, Mercruiser Marine intake (with the 'greentops'), 0411 PCM and Hydroboost braking and ditched the Whipple 'craptronics' (as they're affectionately known).
    I could never really get the idle right...although it wasn't too bad.
    However I had two more serious issues that I just could not sort out (I had pro tuners sitting in the car logging as it happened and we still couldn't find them).
    1) On the first drive for the day the Burb would seriously bog as I went into boost for the first time. Not nailing it...just easing into it.
    2) After driving for a while, if I pulled up at an intersection and then drove off 'normally' the Burb would stumble and stutter until it got going a bit. I could 'drive through' the issue if I gave it a bit more right foot.
    I figured the first one was a 'fueling at cold temps' issue, but it happened even if I'd sat in the driveway and let the vehicle warm up well into op temp. No matter what I logged....couldn't find the issue. felt like it was changing up gears too soon....but it wasn't.
    2nd issue felt like the Burb couldn't make it's mind up what gear it wanted to be in...3rd...2nd..3rd....2nd etc...but logging trans PID's revealed there were no gear changes going on.
    I'd resigned to the conclusion that I'd stuffed something during the trans rebuild or shift kit install and I'd worry about it in a while when I put the 383 in.
    So...I installed the rebuilt, resized LS1 injectors, changed the IFR to suit and loaded the stock injector tables from a factory LS1 5.7L tune.
    The difference all round is amazing.
    The Burb idles better, accelerates smoother and better/harder and is just alot nicer to drive.
    But the best thing.....those 2 issues which have been driving me nuts for about 2 years.....have completely gone!
    If anyone's after injectors...give Jon a call...he's a great guy and great to deal with.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Redline Motorsports
    Guest
    Nice to hear about your happiness! LOL!
    This again proves why good injector characteristic data is important! There is nothing wrong with the 42's other then most DON'T have the correct data.........of course I am refering to the other tables besides IFR.
    You can thank GM's fuel lab for your final results!
    Howard
    Howard, good job...
    Howard, good point...
    The injector related tables are important... the values to use in some of those tables are difficult to arrive at for non-OEM injectors.
    Jan 2007
    Absolutely correct Howard (ha...feels like I'm talking to myself).
    Problem with the 42's is exactly that.....a lack of data.
    Seems IF somebody has the correct data (other than IFR's) they don't wish to share.
    Howard
    DUCT TAPE.
    Jun 2007
    Quote Originally Posted by hquick View Post
    Precisely!
  1. Correct IFR tables for LS3/LS7 injectors in Gen III
    By SweetS10V8 in forum Gen III V8 Specific
    Last Post: August 13th, 2018, 07:27 AM
  2. Old issue fixed, new one now.
    By 05LLYMaxx in forum FlashScan V2 BB Logging
    Last Post: March 1st, 2010, 12:16 PM
  3. New A/C tables in 7.5.5 = fixed my A/C problems
    By ArKay99 in forum Gen III V8 Specific
    Last Post: April 29th, 2009, 04:37 AM
  4. Excess Timing in low load areas causes surge/buck issues, and how I fixed it.
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2008, 12:08 PM
  5. CASE Relearn - FIXED
    By Spindoctor in forum Gen IV V8 Specific
    Last Post: April 1st, 2008, 08:28 AM
