Results 1 to 10 of 16
Thread: Both fans on all the time
    Apr 2008
    Default Both fans on all the time
    Hi,
    I have camaro 98, I swapped both heads then both fans r on all the time. I know that there is no relation between the swap and the fan but it seems like the mechanics did a grounding problem. Any help??
    I made some trials, like shutting them off by the DVT and it worked. And the samething happened with the AC.
    Regards,
    Odd Boy
    Check that the ECT sensor is connected and reading correctly.
    Apr 2008
    I did, it is working and ECT is below on set point
    Regards,
    Odd Boy
    If DVT control can turn the fans off, then the PCM is in control. Make sure you don't have any codes setting, this could make the fans come on. Post up the tun file, something may show up.
    Al
    Apr 2008
    here it is
    Final.tun
    Regards,
    Odd Boy
    Jun 2005
    Are all the grounds on the back of the heads ? Any pending codes?
    Roy 98SSSSSS
    Apr 2008
    IAT code and compressor clutch
    Regards,
    Odd Boy
    Do this:
    - remove the fan relays and see if the fans stop;
    - if the fans stop, then faulty relay(s) or short circuit upstream of relays (causing relays to pull on).
    - if fans continue, then short circuit downstream of relays.
    Apr 2008
    I did that before, when I remove them, fans stop!! I will check the circut
    Regards,
    Odd Boy
    Jun 2005
    Are both fans coming on the moment the car starts up or after a few minutes or after the A/C is engaged. Did you have any A/C work done or r/r a component. I am looking at the schematic and it is pretty straight forward. I am just wondering if it is an input that the PCM is reading incorrect.
    The ones that I canthink of is:
    ECT- exceeds 113'c fans come on
    A/C pressure enable - pressure is greater than 275 psi fans come on
    Also if you have fbody service shop manual, look on page 6-1123 for electrical cooling fan disc. It gives more info than Ican type.
    Roy 98SSSSSS
  1. electric Fans
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2013, 06:01 PM
  2. tuning out fans
    By cajundragger in forum Gen III V8 Specific
    Last Post: December 24th, 2008, 08:38 PM
  3. PIN out #'s for Electric Fans
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2008, 11:14 PM
  4. Auxiliary Fans
    By Chevy366 in forum Lounge
    Last Post: February 27th, 2007, 05:24 PM
  5. COS for E40 and fans
    By Alvin in forum Custom Operating Systems
    Last Post: February 18th, 2007, 09:10 PM
