Results 1 to 7 of 7
Thread: Going from DSP2 switch to DSP5 switch
    Nov 2008
    Default Going from DSP2 switch to DSP5 switch
    Can I just use the same wires or do I need to pull the pins out of the ECM and swap them? I was thinking about splicing so that I wont have to go into the ECM again and have to pull the pin out. Also does the DSP5 switch use the same pin location as the DSP2 pins? I have an 02 duramax, thanks.
    If you have a V2 you could just switch the tunes via your V2...but if you want the switch Im not sure.
    They are on different pins.
    The DSP2 was a simple switch that either grounded the input or didn't, the DSP5 input measures the voltages on the pin.
    As was suggested in the last post, just leave the DSP2 switch in place and switch the DSP5 tunes via the V2.
    Nov 2008
    So what are the pins to use for the DSP5? I don't have the directions for it.
    Dec 2009
    This link dosent work any more. I am looking for a tutorial that will show me how to install the DSP2 in an LB7. I found the document for LBZ/LLY install of the DSP2 but it mentions MANY times that it is only for LBZ and LLY.
    Any help would be appreciated.
    Oct 2004
    I've corrected the URL in the above posts.
    Andrew
    EFILive Crew
  1. how to switch tunes to DSP5????
    By browneflatwork in forum General (Diesel)
    Last Post: February 28th, 2011, 10:27 AM
  2. DSP5 switch for LBZ
    By first timer 6.6 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 19th, 2010, 04:35 PM
  3. DSP2 switch not working
    By silbert in forum Duramax LLY
    Last Post: December 13th, 2009, 11:11 AM
