Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
Thread: Calculating Injector Flow rate
  1. #51
    Apr 2008
    You need to do this:
    - find out wheather your fuel pressure regulator is vacuum-referenced or not...
    if it is, it will be on the fuel rail(s) and have a vacuum hose attached to it;
    - find out your fuel pressure:
    vacuum-referenced: pull the vac hose and measure it,
    non-referenced: measure it;
    do you have any [electric/electronic] device that alters pressure...?
    - find out injector rated flowrate:
    if not stock, what is their rated flowrate and rated pressure...?
    Joe,
    Isn't equal to the pump pressure? (I mean the rail pressure), so if the pump is a stock one, very easy to know its pressure.
    What about depending on efilive scan tool, I found the following (in PIDs):
    DESCRIPTION PARAMETER
    Fuel Rail Pressure SAE.FRP_C
    Fuel Rail Pressure (Gauge) SAE.FRP
    Fuel Rail Pressure Relative To Manifold Vacuum SAE.FRP_B
    Another question, let's say the stock fuel pump gives 58 psig. Is it possible GM designers will rate engine's injectors at lower than that, so we need to correct it when we start tuning??????
    Regards,
    Odd Boy
  2. #52
    Stock pump/regulator pressure is qouted by the GM service manual as 58 psi.
    But don't assume that... measure it, and measure it thru-out the load range (should measure voltage at the same time).
    If you're running an LS1/LS6/LS2/LS7 then the PCM is not measuring rail pressure, it doesn't have a sensor.
    GM engineers rate the stock injectors at 4 bar (58 psi); they may or may not have put the correct values in the IFR table.
  3. #53
    Apr 2008
    thx
    Regards,
    Odd Boy
  4. #54
    Nov 2006
    could someone that knows how this spreadsheet works,(math equation)
    create a new column to paste fuel pressure data for each area of MANVAC?
    so instead of using a constant fuel pressure for each column of MANVAC
    you can scale each separately without doing it manually.
  5. #55
  6. #56
    Apr 2008
    here is the equation:
    new flow in lb/hr = the original fuel injector flow x The square root of ((new fuel pressure+MANVAC) / original fuel pressure)
    Example: car with 24lb injectors rated at 40 psig (at the factory) and will be used with 70 psig pump and the MANVAC=0. Take the square root of ((70 psi (new FPR setting) +0 (MANVAC))/ 40 psi (original FP)) = 1.3229 x 24 lb/hr = 31.75 new flow rate in lb/hr
    refer to the attached file it includes ur request (MANVAC)
    injector calculating for ALL.xls
    Regards,
    Odd Boy
  7. #57
    Nov 2006
    Quote Originally Posted by redhardsupra View Post
    wow!
    your quick.
    looks like i need to get out more.
  8. #58
    Jul 2005
    well it's been there since December of 2006... catch up!
  9. #59
    Apr 2008
    Default IFR adjustments...what if a 2007 single fuel line system?
    Hi folks,
    after reading this thread and letting my head cool down I thought about my conversion.
    I have a 2007 5.3 "LMG" with OEM in tank fuel pump of the same application. GM went to a single fuel line without return. So how do they control the pressure in the fuel rails? Where could I start for adjustments of the IFR?
    Harald
    If nobody has done it before, somebody has to do it....
    1997 Tahoe 2dr 4WD
    2002 Alfa Romeo Sportswagon 2.0 JTD
    1982 Deutz Intrac 2004A
    2003 friesian Horse " Henry"
  10. #60
    Oct 2007
    Quote Originally Posted by harascho View Post
    Hi folks,
    The 'plumbing' has changed with the more recent systems. There is a return of sorts, however it is not external as the more familiar, previous systems. Not sure how helpful this is, as it is a bit vague.
    Gary
  1. Injector flow rate
    By sinr98 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2010, 04:59 AM
  2. Injector Flow Rate
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2009, 10:22 AM
  3. Calculating Injector flow rate
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2007, 09:51 AM
  4. Injector flow rate
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: March 13th, 2007, 04:33 PM
  5. injector flow rate question
    By 9secVette in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2006, 02:04 AM
