Page 18 of 26 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 253
Thread: Flashscan data logging..
  1. #171
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Do you have the blue card that came with EFILive...?
    Open ST or TT and go Help->Register EFILIve and enter all the information from the blue card exactly as shown on blue card (do not enter your name unless the blue card shows your name).
    I should have it... Just need to start digging thru the closet to see if I can find the box.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  2. #172
    Mar 2008
    well.. I found my box and nothing in it but a sticker with a bar code on it, my reciept and a EFILive Flashscan sticker.. So, now what?
  3. #173
    I contacted Tech Support.
  4. #174
    Mar 2008
    O.k... Thanks.
  5. #175
    Quote Originally Posted by waterbug1999 View Post
    Send the FlashScan serial number (the one on the bar code sticker) to me ([email protected]) and I'll send you your license details.
  6. #176
    Mar 2008
    PM sent.
  7. #177
    Mar 2008
    THANKS.. got it working.
  8. #178
    Mar 2008
    Copy the attached Options.txt file to either of:
    WinXP: C:\Documents and Settings\All Users\Application Data\EFILive\V8\Config
    Vista: C:\Program Data\EFILive\V8\Config (I don't remember is this is right).
    Hey Joe.. In here?
  9. #179
    Yes, that's the place, copy Options.txt to there... but do the copy using WIndows Explorer.
    Then in EFILive Explorer in the COnfig Files tab:
    - click Format and let it finish;
    - drag Options.txt and LS1B_A.pmm from the upper pane (Config folder) to the lower pane (Config tab).
    Then goto the Scan Files tab and drag down the dtc .txt files.
    Then goto the Date/Time tab and click Set Now.
    Remove the USB cable, now you're ready to goto car for doing BBL.
  10. #180
    Mar 2008
    I get confused as to window explorer.. where is that.. ugggg.
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
