Send the FlashScan serial number (the one on the bar code sticker) to me ([email protected]) and I'll send you your license details.
PM sent.
1999 Trans Am. 10.71 @ 126 - stock bottom end-
THANKS.. got it working.
Yes, that's the place, copy Options.txt to there... but do the copy using WIndows Explorer.
Then in EFILive Explorer in the COnfig Files tab:
- click Format and let it finish;
- drag Options.txt and LS1B_A.pmm from the upper pane (Config folder) to the lower pane (Config tab).
Then goto the Scan Files tab and drag down the dtc .txt files.
Then goto the Date/Time tab and click Set Now.
Remove the USB cable, now you're ready to goto car for doing BBL.
I get confused as to window explorer.. where is that.. ugggg.
