Page 20 of 26 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 253
Thread: Flashscan data logging..
  1. #191
    Jody,
    [red = do this one time]
    Ok, now connect V2 to PC (for power);
    On V2 LCD/keypad navigate down into setup options, select the SD card, and format it; when done, go back to the opening menu.
    Then on PC, open EE, goto Config Files tab, click Format (formats the config space).
    Then drag these files from upper pane (PC) to lower pane (V2):
    - LS1B_A.pmm <--- means: 1999+ LS1 with A4
    - Options.txt <---- the same one you copied
    Then, goto Scan Data tab, and drag the 4 dtc files from upper to lowe pane (useful for interpreting DTCs).
    Then exit EE, remove V2 from PC.
    [green = do this each time you log]
    Now goto car, ignition key on, connect V2 to car.
    If you haven't done this already, or if you want to change pid list do this:
    On V2 display, go into Select Pids...
    It shows various "pid lists" (i.e. named lists/groups of pids),
    Select one of those (e.g. LOOP or TRANS).
    Press OK one more time.
    Press the ZERO key to start logging.
    When finished logging, press CANCEL two times, remove V2 from car.
    Connect V2 to PC, Start EE, goto Scan Data tab, drag log files from lower pane (V2) to upper pane (some folder on your PC, you may want to change to a different folder).
    In the lower pane, you can delete the log files.
    Exit EE.
    Using scantool, open those log files.
  2. #192
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    ok... i should have the car in the garage tomorrow, so I will try it over the weekend. I just got my N20 bottle filled, bbuuuwwwaaa!!
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  3. #193
    Mar 2008
    Jody,
    [B]Select one of those (e.g. LOOP or TRANS).[/B]
    Exit EE.
    On the V2 for "select PID list" what do I select? I see there is an LS1 99+ Auto.
    But, when I go into option, its doesnt show what PID's are in the LS1 99+ Auto. It just has this.
    ;Cap1 Cap2 Controllers (Engine&Trans) PSL PCU Hot Key (Ctrl+Fx)
    A->, IBPW, LS1B_A.pmm, PSL_A, PCU, 1
    B->, O2S, LS1B_A.pmm, PSL_B, PCU, 2
    C->, STFT, LS1B_A.pmm, PSL_C, PCU
    D->, LOOP, LS1B_A.pmm, PSL_D, PCU, 3
    E->, TRANS, LS1B_A.pmm, PSL_E, PCU, 4
  4. #194
    The new Version 8 "user friendly" black box logging setup software is almost ready to be released, hopefully this weekend.
    I recommend downloading it and using it for black box logging setup once it is available.
    Look for it on our downloads page here in the next 24 hours:
    http://www.efilive.com/index.php?opt...=48&Itemid=133
  5. #195
    Mar 2008
    I remember last year that the names matched in the "options" file and the V2.
    So, I could set this up and use it. which is IBPW in the V2 and select it.. How do I know what group is what in the V2 when the names dont match?
    *PSL_A*
    ;Node PIDs (pid1|pid2|...|pidn) Alarm (min:max:style:time*10ms:hold*sec)
    PCM, RPM
    PCM, VSS
    PCM, TP
    PCM, MAP
    PCM, MAF
    PCM, DYNCYLAIR_M
    PCM, ECT, -40:110:97:1:0
    PCM, IAT
    PCM, SPARKADV
    PCM, KR, 0:2:147:1:0
    PCM, AFR
    PCM, IBPW1
    PCM, IBPW2
    PCM, LONGFT1
    PCM, LONGFT2
    PCM, HO2S11
    PCM, HO2S21
    PCM, MFTOTAL
    PCM, AFR_LC11
    PCM, AFR_LC12
  6. #196
    Quote Originally Posted by waterbug1999 View Post
    Did you drag Options.txt to the Config File tab (the lower pane in EE)...?
    Copy the attached Options.txt to your folder C:\ProgramData\EFILive\V8\Config
    then using EE goto Config Files tab and drag it from the upper pane to the lower pane (with V2 connected).
    lol... Paul will have the new V8/BBL stuff out shortly.
  7. #197
    Feb 2009
    Sweet.
    99 Firebird Formula, M6, LS6 intake, headers, catback, lid, BRE cam.
    EFI V2, V7.5.5 (Build 149)
    V8.1.2 (Build 142)
    Boot Block 2.07.01 Oct 14, 2010
    Firmware 2.07.05 Jan 29, 2011
    LC-1 with serial cable
    COS 5
  8. #198
    Mar 2008
    ok.. I re-did it..
    Where is this in the listings?? I am freaking confused.
    ; __________________________________________________ _______________________
    *PSL,PSL_01,PSL_02
    ;Node PID Alarm (min:max:style:time*10ms:hold*sec)
    PCM, ECT, -40:110:1:1:0
    PCM, CYLAIR_M
    PCM, DYNCYLAIR_M
    PCM, IAT
    PCM, LONGFT1
    PCM, LONGFT2
    PCM, EOPS
    PCM, MAP
    PCM, RPM, 0:6500:2:1:0
    PCM, SPARKADV
    PCM, TP
    PCM, VSS
    PCM, AFR
    PCM, HO2S11
    PCM, HO2S21
    PCM, IBPW1
    PCM, IBPW2
    PCM, KR
    PCM, MAFFREQ
    ;Caption Active Controllers (Engine&Trans) PCU Hot Key (Ctrl+Fx)
    LS1 98|Manual, Y, LS1A_M, PCU
    LS1 98|Auto, Y, LS1A_A, PCU
    LS1 99+|Manual, Y, LS1B_M, PCU, 1
    LS1 99+|Auto, Y, LS1B_A, PCU
    P10|Manual, Y, P10_M, PCU
    P10|Auto, Y, P10_A, PCU
    P12|Manual, Y, P12_M, PCU
    P12|Auto, Y, P12_A, PCU
    E40|Manual, Y, E40, PCU
    E40|Auto, Y, E40&T42, PCU
    E38|Manual, Y, E38, PCU
    E38|Auto, Y, E38&T43, PCU, 2
    E67|Manual, Y, E67, PCU
    E67|Auto, Y, E67&T43, PCU
    LB7|Manual, Y, LB7, PCU
    LB7|Auto, Y, LB7&AL5, PCU, 3
    LLY|Manual, Y, LLY, PCU
    LLY|Auto, Y, LLY&AL5, PCU
    LBZ|Manual, Y, LBZ, PCU
    LBZ|Auto, Y, LBZ&AL6, PCU, 4
    LMM|Manual, Y, LMM, PCU
    LMM|Auto, Y, LMM&AL6, PCU
    Unused, N
    Unused, N
    Unused, N
    Unused, N
    Unused, N
    Unused, N
    Unused, N
    Unused, N
    Unused, N
    Unused, N
  9. #199
    Mar 2008
    So how do you tell what is what?? Im getting ready to go back to the old shit.
  10. #200
    Did you do this (2 steps: copy file to folder, then using EE drag it to Config Folder):
    Did you have V2 attached to your PC when you did that...?
    On V2 goto the Select PIDs option, you will see a "list" of PID lists.
    Each PID list is a group of pids that will be logged if you select that list.
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
