Results 1 to 8 of 8
Thread: scanner buttons work work?
    Default scanner buttons work work?
    my V2 scanner's key pad wont work. the only buttons that work are the down arrow, ok, and back space. does it need to be hooked up to a vehicle for it to work properly? that was just plugged into the labtop.
    Can you connect to your V2 using EFILive Explorer...?
    Goto the Firmware tab and tell us the bootblock and firmware versions.
    idk how to find the EFI live explorer....
    ok found the explorer but when i click on the firmware tab and its empty? If i try to click on the icon for the flash scanner the explorer and scan cal window that is supposed to come up freezes before it even come up
    I notified Tech Support.
    how long does it usually take to get a problem fixed? looking to get the scanner fixed asap so i can do my autoVE and wideband logging
    Quote Originally Posted by pullincrazy88 View Post
    Return it to Fish Tuning. They handle EFILive's FlashScan repairs in the US.
    Their contact details are on our resellers' web page here:
    http://www.efilive.com/index.php?opt...d=38&Itemid=94
    Thanks will call
  1. Does the V2 work w/RR PCM?
    By driver456 in forum FlashScan V2
    Last Post: May 16th, 2010, 12:19 PM
  2. how do i get these to work?
    By whackem04 in forum Black Box Logging
    Last Post: October 27th, 2009, 04:22 PM
  3. How does the PCM work?
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: June 7th, 2008, 06:22 AM
  4. Will this work
    By Koo in forum EFILive V4
    Last Post: February 15th, 2008, 10:59 PM
