Pretty snazzy , good job .
2006 Trailblazer
When saving settings F6 stuff to the V2 unit I get a "Error: $010A Recieved data message contained unknown command action"
This was after setting serial IO
2008 Z06 C6 Corvette
Did you go to the Windows task bar lower right and click V2 icon and update firmware ?
Got same error until I did that .
2006 Trailblazer
When saving the settings to FlashScan, there needed to be some way to tell FlashScan that the settings had been changed and to re-read the Settings.dat file. I had to add a new command to the FlashScan firmware to do that. Older firmware won't recognize that command and will give you the error you see.
As Chevy366 said, upgrade the firmware to the latest V2.06.08 available in the latest V8 dowbnload on our downloads page.
Noticed that with new build that just plugging in V2 does not trigger recognition of device , you have to physically select device in FlashScan and AutoCal Device Settings (lower right corner of window AutoCal or FlashScan)to get task bar tray icon of V2 for firmware updates .
2006 Trailblazer
When setting up custom units and you click the clear button, it exits back to the main BBL window. Shouldnt it just clear the values and keep the custom units pane open? Does it regardless if there are values in the min/max fields or not.
Another question, any way to make it so when you put a PID in the Selected PIDs area in S&T BBL to have them disappear from Available PIDs? Right now when you add the same PID again it just moves where the PID was in the list, but I think having it disappear completely from the Available PIDs is a good idea.
Third round here, whew! When you add a new controller selection, go to add the PIDs you wish to scan with, save the Options.txt file to your PC, and then click Program it appears everything works properly. However if you are using a different controller that you have not copied the *.pmm file to V2 already it will NOT program the new *.pmm file that isnt on V2 without first closing and restarting S&T BBL. (ie I made a dummy LS1 99-08 PID selection and programmed it but the LS1 99-09 .pmm file was not copied over.) Doesnt matter if I select Program All PMM Files (slower) or not, doesnt copy the new .pmm's till the program is relaunched.
There is a fault with the V2.06.08 firmware, please read the "Known Issues" here:
http://www.efilive.com/index.php?opt...tes&Itemid=134
The auto update will not download Build 53,
I'm stuck on Build 52.
LC-1 WBO2
