Results 11 to 20 of 40
Thread: Car is running VERY rich all of a sudden
    Mar 2007
    joecar, I'm using a female to female serial adapter I got from radioshack. no analog signals are being used.
    mr.prick, I'm pretty sure the WB is hooked up correctly. I had a hell of a time getting the LC1 setup and operating the way it should but I'm sure its set to gas 14.7afr. I might try another recalibration ( I only did about half a dozen so far) to be sure the HUGE a/f swings aren't a miscalibrated sensor. it does hover around 14.7 a few minutes at startup and while I'm crusing but its not nearly as steady of a reading as my LM1 is.
    Oct 2006
    Use "serial" with the V2 , LC-1 combo , the LC-1 1.10v firmware is flaky in analog form .
    Hmmm , like joecar says in a CO3 the O2s are only active if you have a semi-open loop mode enabled .
    No DTCs ?
    2006 Trailblazer
    Mar 2007
    ^^ how would I know if semi-open loop mode enabled... can't that be figured out by looking at the log, it doesn't appear that the o2 voltages move that much.
    female-female won't work... you need a null-modem adapter... see this:
    http://www.sfcable.com/cable/p/30D1-C1-S.html
    showthread.php?p=80536 post #2
    Or get a pre-made LC-1 serial cable from TAQuickness:
    showthread.php?t=8858
    Mar 2007
    ^ that pic looks exactly like the adapter I have... except I don't know if it says null modem on it, I don't think it does. So I guess that means I've got the wrong adapter, bummer. I'm going to order the one from the link you posted right now, THANK YOU!
    Mar 2007
    Mar 2007
    will this one work? It says null modem adapter but I think its male on one side and female on the other... not 100%
    http://www.radioshack.com/product/in...&tab=techSpecs
    sorry for all the questions.
    See how the null modem adapter crosses pins 2 and 3...
  9. #19
    Mar 2007
    I'm an idiot sometimes... thanks for the HUGE pic
  10. #20
    Oct 2006
    Get the LC-1 cable form TAQuickness , direct connect .
    2006 Trailblazer
  1. running rich between shifts??
    By smslyguy in forum Gen III V8 Specific
    Last Post: October 8th, 2009, 09:53 AM
  2. Car is running VERY rich all of a sudden!
    By alwaysinboost in forum Gen III V8 Specific
    Last Post: May 19th, 2009, 03:03 AM
  3. 5.7 running rich.
    By DmaxHawk in forum Vortec V6/V8 Specific
    Last Post: January 21st, 2009, 06:40 AM
  4. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
  5. It's running a little rich
    Last Post: January 23rd, 2007, 02:30 PM
