Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 84
Thread: EFILive Version 8 (Black Box Logging) is now available
  1. #51
    Oct 2005
    Something like this... http://www.hcc-embedded.com/en/produ...ystems/safefat
    Alternatively I've been investigating into not having a Config FAT file system but just storing the Config data in an internal fail-safe format. There's no reason to store the Config data in a FAT file system as it is not removable and no other device/computer will ever need to access it.
    Yeah, either or.
    You could almost steal all the internal memory for system use and force people to use SD Cards, they are almost free now anyway. (Then save DTC code info in there too
    2008 Z06 C6 Corvette
  2. #52
    Quote Originally Posted by ringram View Post
    Yeah, either or.
    Hmm, except AutoCal has no external memory. So I need to support all the functions on the internal memory anyway.
  3. #53
    I'm being dense....how do I get my log file off the V2 with the new software?
    I just know this is going to be obvious and I'll feel silly.....but I just can't see it?
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
  4. #54
    Nov 2006
    I have not used BBL for awhile but IIRC,
    you can drag and drop it from EE.
    LC-1 WBO2
  5. #55
    I was OK doing that with the old EE, but with the new Carlos Fandango one.....I can't see how to (I know this is me just being thick!!)
  6. #56
    Nov 2006
    It should be the same.
    FWIW the old EE short cut opens EFILive scan and tune now.
    You will need to navigate to C:\Program Files\EFILive\V8 and
    create a new shortcut for EE, it has a new look.
    LC-1 WBO2
  7. #57
    OK, had a look in there and the cupboard was bare......zapped everything and started again. Bingo EE staring me in the face, I must have biffed something up during the install (in my defence I was rushed/didn't bother reading anything )
    Jim
  8. #58
    Sep 2007
    Quote Originally Posted by Biodiesel66 View Post
    Paul,
    Couldn't get the TEMP1 or TEMP2 to work with build 51 or 52. When using EFI S&T, adding TEMP2 External Temperature to the Selected PID list, changing the properties to custom. Default ID Properties: Node: is empty!
    Custom ID Properties: Quick set is empty, should have °F or °K ? Had to change the Factor, Offset, and Units. Click OK. Saved the PID and programed to F/S with S&T. The selected PID will not view or record. If I go and Edit the Options txt file and change ( ) to (-,) for the controller and save the file. View it in EFI S&T for that selected PID and check the properties the Node: has - and is not empty. Program the changed Options txt to F/S. It will view in °F and play back in °F. WHY does it work this way and not the other way?
    The 3 PIDs should have logged in IMPERIAL from the Options txt setting.
    The PIDs that are listed are from F8 in the log and from the customized PID list that can be viewed in Imperial from F/S or A/C. The log has them as metric. F/S can't change 2 of the PIDs to IMPERIAL because the UNITS are set by default to metric. Its just like FRP_C. F/S has the UNITS set to PSI, Default Metric or Imperial. The recorded log will only play back in PSI never metric. Until it's changed in F/S.
    Did you get anything on this? I'm having the same problem and wondered if there was a work around so I could log my EGT, please?
  9. #59
    I'm looking at this now...
    Follow in this thread:
    http://forum.efilive.com/showthread....5334#post95334
  10. #60
    Sep 2007
    Thank you - This new release is INCREDIBLE!!! I LOVE the new BBL!
  1. EFILIVE V8 Black Box Logging Questions - Imperial units?
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: May 13th, 2009, 01:21 PM
  2. V2 Black Box Logging
    By Blacky in forum FlashScan V2
    Last Post: November 4th, 2007, 10:51 PM
  3. V2 black box logging?
    By articSS in forum FlashScan V2
    Last Post: September 23rd, 2007, 04:57 AM
  4. is black box logging available on v2 yet ?
    By imtduncan in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2007, 12:11 PM
  5. Black Box Logging Bug ?
    By Ninety8C5 in forum General
    Last Post: July 24th, 2006, 02:31 PM
