Results 1 to 10 of 22
Thread: External AD and TEMP inputs
    Long story short, it appears the A/D converters are sampling too fast and the latest firmware is not processing the AD interrupts fast enough.
    The AD interrupts are currently coded to interrupt the CPU 4 times at 4us intervals for the 4 A/D inputs (16us in total). After the latest additions, the firmware was not able to process AD1 within 4us of requesting the AD cycle and was dropping AD2.
    I've changed the 4us to 8us (32us total) and the firmware works correctly again.
    Try this firmware to see if it fixes the AD2 problem.
    I've kept the version at 2.06.10 so you can swap back and forward between this version (May 24) and the previous V2.06.10 (May 20) version.
  1. External AD and TEMP inputs
    By Blacky in forum Do you want to be a Beta Tester?
    Last Post: May 23rd, 2009, 01:49 PM
  2. Resolution of V1/V2 A/D inputs?
    By Garry in forum External A/D inputs
    Last Post: January 3rd, 2009, 11:56 AM
