Results 1 to 10 of 12
Thread: LC-1 serial connection
    Mar 2009
    Default LC-1 serial connection
    i know there is a million threads about this but i read them all and cant fix my problem. i have connected the "out" of my LC-1 to the serial cable it came with to a gender bender adapter then into my flashscan. the "in" of my lc-1 it has that stopper connecter. i set up all the options as the pfd tutorial said but still cant get it to connect. it works fine in analouge connected to the v2.
    Nov 2006
    Do you have all the serial PIDs selected?
    Serial Wideband Tutorial
    LC-1 WBO2
    Mar 2009
    i was just trying to get the v2 to connect by itself. i went into display WO2 not connected to laptop.
    A gender bender is insufficient... it has to be a null modem adapter (crosses pins 2 and 3).
    female-female won't work... you need a null-modem adapter... see this:
    http://www.sfcable.com/cable/p/30D1-C1-S.html
    showthread.php?p=80536 post #2
    Or get a pre-made LC-1 serial cable from TAQuickness:
    showthread.php?t=8858
    Nov 2006
    This is very important.
    LOL when serial first came out I bought a standard gender bender too.
    Only a null modem will work.
    IMO make you own direct cable or buy one from TAQCables
    LC-1 WBO2
    Mar 2009
    yeah figured that out thismourning i just rigged up some cable to test it crossed 2 and 3 over and bingo. i didnt buy the gender bender just grabbed it from work lucky haha. i have a cable made up now, but i have another problem now the flashscan is not connecting to my computer. i plug it in and i get only the far right yellow light lit. no lcd screen. a couple times i plugged it in i got 3 lights on but no lcd. it still works fine on the car however somthing happened either when i set up the serial lc-1 or when i installed a usb to serial adapter. argh..... annoying cant it just work.
    Mar 2009
    i think its going back for warrenty it wont connect to my laptop but works fine on the car.
    Nov 2006
    LC-1 WBO2
    Mar 2009
    I don’t get any of that POST stuff. if i connect it to the car it works perfect boots logs (BBL). but if i connect it to the computer by usb it doesn’t work at all. ill explain exactly what happens when I plug in the usb cable.
    1) The first time i connect it after its been disconnected for over 1 min the 4 lights to the right will light up dimly. The blue light will light bright for a half a second then go dim like the rest. No flashing, no anything else any button press has no effect either.
    2) If I unplug it then quickly reconnect the usb cable to the computer only the far right yellow light, lights dimly.
    I’m sure that’s not normal I think its dead.
    Nov 2006
    Have you tried connecting to a different computer?
    Can you connect to the car and computer? (passthru)
    LC-1 WBO2
  1. Not connection to E67 ECM
    By khalidmmukhtar in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 08:40 AM
  2. No connection!
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2008, 12:33 PM
  3. No connection
    By jannes_z-28 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2007, 08:57 AM
  4. connection problem
    By 98RedZone in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2007, 03:20 PM
