Hi guys, EFILive BBL etc: fabulous capability taking shape there.
PID editor is right out there! It was all kinda hard before this great tool!
A few issues come to light today as I wade through the learning curve of using build 55 capabilties etc.
These may have been reported already and already be on the to do list, so I will keep it short:
A/. For BBL display or log pids, V2 Selects both WB02 sensors on BBL. i.e. in options select one sensor, on scan/log two are presented. Seems that they always use 3 lines each too. Could do with just Lambda.
B/. Some items that are selected, are in log, do not appear on V2 BBL screen.
C/. Some items that are selected, are not in log, do not appear on V2 BBL screen - examples:
TCM VSS PID when selected has gone missing from V2 and log....it worked before.
PID's SCALCORVE_M & it uncorrected partner while listed in the FS V2 PID list, do not appear on the V2 or log.
Probably a few others to come.... :0
D/. Selecting Lambda in Flashscan and Autocal Device Settings "F7" sees EQR on the V2. (can be changed in V2 options.)
E/. De-selecting "Auto Select all digital PID's", turns all digital off. (i.e.needs 0,1,2 option ?)
F/. Selecting 1 Wideband sets in the editor or in the V2 selects both WB PIDs. Techedge WB. (see also A....I may be stuttering....)
G/. In FS/AC PID selections, ECM PID descriptions come and go, and descriptions get out of order.
H/. Sometimes V2 will notify writing log file, but nothing ends up on the SD card.
Back to the grind.....
Cheers, Ian
PS - For those of us with 64k row limits in XL, it would be good when exporting large logs if they produce a seperate file (auto) for every 64k rows or so. Not the end of the world of course.
