hi
i need tuend & stock files for my car its 1999 gmc yukon 5.7 l31 with 4l60e 2wd cuz i Corrupted my files
hi
the tuned files just for max performance in stock black box pcm cam any 1 send them 2 me plez
LC-1 WBO2
thanx but
I cant fined my car there.. :(
Click on the link that Mr.Prick posted---Go to Stock Tunes---Scroll down to the 99 Suburban tune. That should get you going.
Jeff
98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
Down load the tune that is installed in your PCM and save it.
LC-1 WBO2
HMMM!!! I guess that would be the thing to do. I figured his installed tune was not good and his saved tunes were corrupt.
Jeff
what about Modified Tunes
