Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Imperial pids for BBL?
    Jun 2009
    Default Imperial pids for BBL?
    I looked around and didn't see anything on this.
    When setting up the PID selection to load into my v2 the temps, speeds, ect are all metric.
    How do I get imperial PIDs into the list to use?
    Lifetime Member samh_08's Avatar
    Oct 2008
    1) Open up the V8 Scan and Tune software,
    2) Click on BBL,
    3) Select the PIDs you want logged on your controller,
    4) Once you have all your PIDs selected you can right click on them and click properties,
    5) You should see a 'custom' section,
    6) Select the imperial unit you want the PID to be displayed and logged as
    7) FYI: You can toggle between metric and custom by pressing 'enter' on your V2 unit
    Good luck
    Lifetime Member LBZoom's Avatar
    Jun 2008
    When I do that with mine, it won't allow me to change it to imperial...not sure what's going on. Anybody have any ideas? Haven't tried toggling on my V2 yet. Can someone paste a copy of the default LBZ pid descriptions on here so I can get them? I was messing with some stuff I shouldn't have, enough said lol. Thanks.
    Peace Through Torque
    www.PunisherPerformance.com
    Nov 2006
    LC-1 WBO2
    Jun 2009
    thanks! that worked wonders for me
    I tried right clicking on them before I asked, but I was doing it before I added them to my list
    Mar 2009
    Have the same issue with mine...doesn't give me any options in the drop down box for metric/imperial selection. Am I missing something?
    Apr 2008
    Same thing going on for me. I have not tried it on the new build 58 till now. It did work for me for sure in build 55. Looks like a bug in build 88 maybe. Unless others have no issue in build 88.
    Brian
    Mar 2009
    Quote Originally Posted by Brian1 View Post
    Brian
    I'm on 58 myself...but no go.
    Sep 2003
    I'm not sure but it looks like the V8 'Options.txt' file is not looking at the 'EFILive.ini' file for the alternate (Imperial) measurements. If they were in the 'Options.txt' file from an earlier version they are still there but nothing new can be added. I haven't tried loggng to see if the PIDs values show up in Imperial or Metric. Will give it a try when I get a chance.
    Just hooked up V2 to car and PIDs in Imperial as they are in my 'Options.txt' file.
    Apr 2008
    Yes my current options.txt file has some in Imperial and is fine there. Just adding new PIDs or even trying to change current PIDs back to Metric if Imperial or vice a versa no longer exist.
    Brian
  1. Question displaying Imperial during BBL
    By Brian1 in forum FlashScan V2 BB Logging
    Last Post: November 8th, 2009, 02:15 PM
  2. Imperial vs Metric
    By killerbee in forum General (Diesel)
    Last Post: September 3rd, 2009, 09:16 AM
  3. Changing Pids to Imperial??????
    By turboolds in forum FlashScan V2 BB Logging
    Last Post: June 17th, 2009, 10:17 AM
  4. Imperial MAP values seem backwards
    By kp in forum General
    Last Post: March 9th, 2005, 06:40 PM
  5. Imperial MAF units in the V7 scan tool
    By XLR8NSS in forum General
    Last Post: February 26th, 2005, 11:38 PM
