Results 1 to 2 of 2
Thread: Funky Vin = cant log
    Default Funky Vin = cant log
    I keep getting a funky vin# when connecting to my LB7 and only a select few PIDs show up ...LLY is normal and can log everything
    I can flash it with the road runner and the truck starts and turns over fine,but i need to be able to log, Atleast rail pressure.
    Last time this happened I needed a new ECM is that the case here?: help2:
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
    Try setting the correct VIN in the Tuning Tool, save the *.tun file, then full flash it using the RoadRunner full flash option. That should restore the VIN in the RR ECM.
  1. Funky Rev-Limiter Like Symptom GTO
    By E.A. in forum Gen IV V8 Specific
    Last Post: July 12th, 2012, 08:20 AM
  2. New update - speedo calc. still funky
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 25th, 2008, 08:14 AM
