Results 1 to 8 of 8
Thread: first tune please pick apart.
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default first tune please pick apart.
    Here is my first tune woundering if there is anything i can changed or should change on it?? first run with new tune on.efi
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Jul 2008
    From just looking at your log it looks very good.
    No KR, LTFT's are slightly negative, injectors max out ~71% (good).
    My only question would be do you have a wideband?
    Oct 2008
    I don't have a wideband yet, but it's in the making. No issues at all with this tune. It really woke this car up big time. I am very pleased with it. I still do have the cat protection mode enabled. Would you see this as a problem? Maybe as to why the LTFT are in the -??
    Jul 2008
    No, it is O.K. to have your LTFT's in the negative. Overall, thats more favorable for WOT fueling (no extra fuel added).
    As far as COTP enabled, when you get your wideband I would disable it. Under COTP AFR's are ~11.9, way to rich for maximum performance. IMO, as long as you are not doing 3-4 rapid-fire WOT of >15 seconds, your cats will be 'fine'.
    I believe the Commanded Fuel Pid GM AFR does not reflect when COTP is being utilized. Just a F.Y.I., as your log on GM AFR indicates.
    With no KR, and the rest of your tune looking good I seriously doubt you are running lean. The wideband would just give you the confidence of a having the AFR at WOT that you want. Disabling COTP will give you a a even nicer WOT pull.
    We have seem some evidence that COTP does show up sometimes in the commanded AFR... yeah, it confused me... the cats should be fine with COTP disabled unless you're doing extended period WOT pulls.
    Jul 2007
    Quote Originally Posted by smslyguy View Post
    At 02 sensor readings consistently around 905mv, I ran around 12.7:1 AFR consistently with my stock Z06 and airbox. At slightly above 890mv, I found the car pulled real hard. I settled with around 905-911. At less than 890mv, I found a slightly lean mix.
    Your tune looks good, but I would recommend you consider a slightly richer mix on top.
    07 Silverado DMax Classic
    Oct 2008
    I have noticed now with the temps in the 80's that i do have some kr a lower underload speeds with this tune. but as long as i don't "bog" the motor down and i keep the rpm's up i don't incure any kr. Would you see this as a problem having knock or should i get reduce the timing in the lower rpm's? I have attached another run without cat protection inabled and also at a warmer temp.
    Oct 2008
    Quote Originally Posted by TFZ_Z06 View Post
    at what a.f.r would you recomend on top end?
  1. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  2. Looking to pick up the RoadRunner
    By Whippled 496 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 13th, 2008, 11:18 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
  5. Will Flash scan pick up Emission failure codes
    By Biodiesel66 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2006, 12:33 PM
