Results 1 to 5 of 5
Thread: Can I scan a '97 Vortec 5.7 Tahoe
    Junior Member Denaliano's Avatar
    Apr 2007
    Default Can I scan a '97 Vortec 5.7 Tahoe
    Won't let me choose a PCM. only 98-00.
    I'm trying to pull up some codes. I can blackbox log, and read... correct?
    I log, and it only shows one code. P0420.. Are there other codes it may not be showing me?
    Not to familiar with using this method to retrieve codes.
    - 2002 GMC Sierra Denali Quadrasteer 6.0L AWD, 4.10s, K&N FIPK -
    Post some screenshots.
    Jan 2007
    Thought it needed to be 98+ and only with the V2???
    Denaliano....do the 0411 swap and use EFILive's full potential.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Nov 2006
    We need a Supported Vehicles sticky in the Please Read First forum
    LC-1 WBO2
    To scan only, try selecting 1999-2008 LS1 and see if that works.
  1. 01 5.3/Tahoe..
    By Chuck L. in forum Gen III V8 Specific
    Last Post: August 15th, 2008, 03:15 PM
  2. Help Cannot flash 99 tahoe
    By 94caprice00gmc in forum Vortec V6/V8 Specific
    Last Post: February 6th, 2008, 07:21 AM
  3. 07 Tahoe e38 pcm
    By 5.3 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 10:02 AM
  4. 07 Tahoe supported???
    By 5.3 in forum Gen IV V8 Specific
    Last Post: November 27th, 2006, 02:01 PM
  5. i just got my 07 tahoe today.
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 1st, 2006, 05:14 AM
