Results 11 to 20 of 23
Thread: 96 to 01 '0411 conversion; S10 4.3 newb ?
    Aug 2006
    If your VSS worked on the Black Box PCM then you should be good to go. Us V-8 guys use the 01-02 Operating systems. I know they have Custom Operating systems for those years---I would probably try to use one of those years.
    Hey Stealth---Whats Up
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Member overS10ded's Avatar
    Mar 2009
    Default KS DTC code P0327
    I've been driving on the '0411 for a while and it is much smoother start and idle. The start-up idles down much, much faster then the old black box that seemed like there was a vaccum leak the way the idle "searched" down slowly, but the '0411 snaps quickly, very responsive.
    I do have the P0327 KS code that is keeping the revvs from producing good power, holding the timing back. I would appreciate any help concerning this issue. Thanks much.
    Good times!!
    Bruce
    Aug 2007
    You need to change your knock sensor to one outta a 2001 and up 4.3l.
    Mar 2009
    Quote Originally Posted by chevy052500hd View Post
    Thanks a million!!! I am swapping to the marine manifold and will replace the knock sensor then. I appreciate your help!
    Good times!!
    Bruce
    Aug 2007
    the one outta a 2001 is a 2 wire design and has a bolt that goes throught the middle of it I just got a 1/4 npt pipe plug and drilled and tapped it to accept a 1/4 20 to hold the new sensor down. Once you get to the sensor you will know what I am talking about. In efilive you can change what type of sensor it is but I think the values for the 327 trouble code are not available for use to modify via efilive, because even after I changed all the values I would still get that code, thats when I just swapped sensors.
    Mar 2009
    Double that million I thanked you with before!! I really appreciate your information, this helps me alot. Saves me a lot of time too! Hope I can return the favor.
    Good times!!
    Bruce
    Mar 2009
    What pins (pinouts) did you use on the '0411 for this KS? Thanks for your help!!
    Good times!
    Bruce
    Aug 2007
    I seem to remember 11 and 51 on the blue pcm connector, but let me confirm this once I get back to the truck
    2005 chevy silverado, duramax tuned with efilive
    1997 Saturn sc2 turbo, tuned with megasquirt on e85
    2000 s-10 turbo'd tuned with efilive on e85
  9. #19
    Mar 2009
    OK! I appreciate that info and will welcome your confirmation. Thanks again!
    Good times!
    Bruce
  10. #20
    Aug 2007
    Okay I got it,
    PCM
    Pin 9 is KS signal dark blue
    Pin 49 is KS 5V Reference
    On KS Connector
    Pin A is KS Signal dark blue
    Pin B is KS 5V Ref.
    Hope this helps
  1. 0411 conversion issue
    By makoskey in forum Gen III V8 Specific
    Last Post: July 28th, 2016, 05:42 PM
  2. Help a newb!
    By The Cartel in forum Black Box Logging
    Last Post: July 30th, 2009, 02:01 PM
  3. newb needs help
    By pdasterly in forum Gen III V8 Specific
    Last Post: March 4th, 2009, 11:11 PM
  4. newb
    By LearnMeEFI in forum Duramax LLY
    Last Post: October 8th, 2007, 02:41 AM
  5. Newb checking in!
    By Kevin Doe in forum Lounge
    Last Post: October 1st, 2007, 04:28 AM
