Results 21 to 30 of 35
Thread: Page 13 in the AutoVE Tuning guide.
  1. #21
    Nov 2006
    Assuming you are in CL with PE on,
    {B3618} is the commanded AFR for PE.
    Change that to the AFR you want per RPM.
    On a side note the Logworks software download is at the top of
    Innovates support page.
    LC-1 WBO2
  2. #22
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Just to make sure, what should I check/what should it be? I should be in what the end of the tutorial put me in. You know I am an failure so far at understanding this stuff.. The plan is to buy the learning software that was posted a few weeks back, but the girlfriend (we live together) is going thru cancer so $$ is tight.. this is why I started to try the tuning, is free as i paid for EFILive a few years back.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  3. #23
    Nov 2006
    My prayers go out to your GF.
    For AFR it depends on the octane you have available and your application, N/A or FI.
    12.5 AFR at WOT is not too rich for N/A.
    LC-1 WBO2
  4. #24
    We hope/pray your GF is going to be fine/healed.
  5. #25
    Mar 2008
    Its cool guys, thanks... She went true surgery and nows its all chemo, shes half done.
    DRKPHX and I went for a cruise today... here is the data log. Im just trying to lean it out up top fro max HP.
  6. #26
    Mar 2008
    So, I removed the MAF and did some more ve logging. Question is how much "smoothing" do you do?
    Here is the way it is with out.
    And a few clicks for smoothing.
  7. #27
    Mar 2008
    Well, I took it for a spin.. looks a little lean up top, I am assuming its because of me taking off the MAF. Should I added a little more in the main VE table in that area?
  8. #28
    Quote Originally Posted by waterbug1999 View Post
    Jody,
    Just a little smoothing, just like you have done...
  9. #29
    Mar 2008
    Jody,
    ok..
    Hey, so if under WOT its a little lean, I just find that area in the Main VE table from highlighting it in the log then up the number? So, lean = + #'s and rich = - #'s?
    And do you do the same in the backup VE table as well?
  10. #30
    Nov 2006
    ok..
    If you are using the LTFT method use the 2 filters on the Main VE then copy the Main VE to the Back up VE.
    LC-1 WBO2
  1. New beginner's Tuning Guide (DVD) from Calibrated Success
    By eficalibrator in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2010, 05:49 AM
  2. Tuning Beginners Guide
    By NASABlue in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 02:37 AM
  3. Noob's guide to Dyno tuning?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2008, 08:25 AM
  4. Beginners guide to tuning
    By ringram in forum Tutorials
    Last Post: June 17th, 2006, 10:46 PM
  5. PCM tuning guide
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2004, 05:42 AM
