Results 1 to 9 of 9
Thread: Turning Off Codes Not Found
    Jan 2016
    Default Turning Off Codes Not Found
    Can someone please tell me how to turn off specific codes in EFI Live V2 on a 6.7L 2007 cummins? I have tuned cars with hptuners and it was simple but for whatever reason I do not see it in EFI Live V2.
    Dec 2012
    Read file and open in v7, save file and flash
    2005 Cummins - EFILive Conversion - S474 single - 1325hp on the spray.
    Jan 2016
    I have version 7.5 but I guess I dont see it?
    Under Diagnostics >> DTC List
    The only other thing I can think of is it is possible not all OS's had the DTC's mapped (it is a diabolical task on Cummins) so you may have got unlucky with the one you have there.
    Jan 2016
    Thanks, I see now where you have to open the diagnostic error detection and look for the values. A tip for efi would be to sort that ridiculous list!!!
    Calibrations --> Internal Flash -->Diagnostics --> Diagnostic Error Detection
    Quote Originally Posted by EverydayDiesel View Post
    It is numerically sorted which is NOT how it is stored in the ECM, we can display it like like it is set out in the DTC array in the ECM then you can call it a ridiculous list all you want.
    Cummins programmers need to take a tip from GM's software guys on DTC arrays.
    Jan 2016
    Thanks for the help. I just mean that being able to sort that grid box from a column header click event would be nice. (i am a c/c++ developer)
    I meant no offence.
    Nov 2018
    Hi can you please give me a better understanding of how you found that? I'm having a lot of trouble finding the DTC's for my 2018 2.8 duramax.
    Senior Member KhakiCummins's Avatar
    Sep 2011
    DTCs are not available on any diesel 2010 or newer.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
  1. Reading Codes on V2 -Descriptions NOT FOUND
    By jurish in forum FlashScan V2
    Last Post: July 14th, 2013, 02:05 AM
  2. Turning off a Trans Limp? Is it possible?
    By Mitco39 in forum Allison 5 & 6 Speed
    Last Post: August 24th, 2012, 04:49 AM
  3. turning a 60 to a 60e
    By bob94z28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 14th, 2007, 05:29 AM
  4. Turning off Knock sensor?
    By SinCity-Z in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2007, 01:52 PM
  5. turning off 02 while tuning
    Last Post: May 5th, 2006, 05:58 AM
