Results 1 to 5 of 5
Thread: No start 2013' dodge code$0280
    Apr 2015
    Default No start 2013' dodge code$0280
    Long story short wife pulled up at the house turned truck off 10 min later went to start and nothing happened. Turn key on all lights come on but nothing when u turn to start. DTC code is $0280. Tried to reflash the tune and auto cal gives error$0549. Truck is a 2013 dodge and has been tuned for about 2 months with no issues. Any help is greatly appreciated.
    Nov 2010
    Have you contacted your tuner?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Apr 2015
    Hoping to get ahold of him tomorrow if no one can help me tonight
    Quote Originally Posted by Kmg2012 View Post
    You mean P0280?
    P0280 Injector Solenoid Driver Cylinder #7 Current Too High
    EFILive error $0549 on a Dodge usually results from not being able to communicate with the ECM at all. Unfortunately I think something has failed on the truck.
    Jan 2009
    We had this same issue, are you using a bullydog to monitor the truck? We have had bullydogs shut down the canbus on the trucks, the only way to get it back (atleast from what we found) is disconnect the bullydog unplug both batts and let it sit for 5 mins then reconnect. Something in their units can cause the whole system to shut down on the truck and not reboot even after you unplug it.
    The fact that your are getting $0280 would have me believe this is what is happening.
  1. ERROR CODE 0280 not conntected
    By speedo in forum General
    Last Post: May 12th, 2015, 07:46 PM
  2. 2005 dodge
    By wickedcummins in forum Do you want to be a Beta Tester?
    Last Post: October 15th, 2012, 02:18 PM
  3. 05 Dodge Ram
    By Zero1338 in forum Do you want to be a Beta Tester?
    Last Post: August 14th, 2012, 12:22 PM
  4. Code U1000 Security Light on No start. HELP!!!
    By ls698ta in forum Gen III V8 Specific
    Last Post: February 14th, 2009, 09:28 AM
