Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 117
Thread: PLX SM-AFR Serial upgrade
    Senior Member SV8346's Avatar
    Nov 2007
    does this mean that we cant log OBD2 while the serial cable for AFRs is plugged in. Only thing we can see is AFR's, is there a way of being able to plug in both the OBD cable and the serial cable to be able to read the AFR's allot more accurate and also log the cars activities?
    2016 RG Colorado 2.8TD
    Quote Originally Posted by SV8346 View Post
    The wide band serial cable connects to the RJ12 (6 pin) connector next to the USB connector at the top of FlashScan.
    The OBDII cable connects to the RJ45 (8 pin) connector at the base of FlashScan.
    So yes you can (and must) log wide band O2 data simultaneously with OBDII data.
    Nov 2007
    ahhh ok sweet, now i gotcha. Well i look forward to this in the very near future as at the moment i am only view PLX afr through the 2 pin connectors in the base of the V2.
    Lifetime Member Chalky's Avatar
    Sep 2003
    The serial cable ships with FlashScan. It has an RJ12 plug on one end to fit into FlashScan and a 9 pin serial plug on the other end.
    Guess I need to find my original packaging.
    2015 Z06 A8
    Sep 2003
    So this is what I need? (The Link is old from OP)
    MAX232 RS232 to TTL Converter Board.
    I can't find my serial/RJ12 cable from EFILive. I was going to have one made locally if practical or order a new one. Can someone give me specs on how a cable should be configured to work between the DB9 and Flashscan V2?
    Thanks in advance.
    2015 Z06 A8
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    I found my serial cable from EFILive and must say it is of good quality.
    The only thing I noticed was that I required a gender bender because the DB9 plug on the RS232 converter was male and so was the plug end on the EFIlive serial cable.
    You can make a cable but the EFiLive cable is to sweet.
    Look back through the threads and find the picture of the RJ12 plug and the phone jack, that will explain the RJ12 end.
    This was a pic I dug up on the RS232 Converter that I purchased, so it should give you a better idea on the DB9 end.
    Mick
    Rev it up, Drop the clutch, See what happens?
    Here's a gender bender that works with the EFILive serial cable:
    http://www.sfcable.com/cable/p/30D1-C1-S.html
    Sep 2003
    Red face
    Quote Originally Posted by MICK View Post
    Mick
    Thanks. Blacky ended up saving me the trouble of building my own. He must be aware of my limitations.
    2015 Z06 A8
  9. #19
    Lifetime Member JezzaB's Avatar
    Nov 2006
    A gender bender wont work with the way they we modified the PLX.
    That TTL converter board is a female but when you put the gender bender on to the V2 cable it wont work because the entire plug is the same wiring as the V2 cable. I havent tried a null modem cable yet coz i dont have laying around (but it should work). I just made a cable up exactly like Mick did.
    RJ12 plug
    flat cable
    DB9 Male plug and used the shell that came with the TTL Converter.
    I couldnt find any converter boards that had a male on them and if you soldered one you, you have to cut tracks and re-route them.
    Jez
  10. #20
    Jul 2007
    For those that want to try replacing the female socket on the RS-232 converter with a male, this is what you should end up with....
ID:	3121   Click image for larger version.
ID:	3122   Click image for larger version.
  1. BBL & Serial LC-1
    By L31Sleeper in forum FlashScan V2 BB Logging
    Last Post: January 19th, 2010, 12:01 PM
  2. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
  3. Replies: 50
    Last Post: March 15th, 2009, 04:00 PM
  4. Where are we with serial WB???
    By Redline Motorsports in forum FlashScan V2
    Last Post: August 13th, 2008, 09:26 AM
  5. WB serial to LT serial?
    Last Post: May 12th, 2008, 10:17 AM
