Thanks a lot !!!!!
Will let you know tomorrow !!!
Thanks a lot !!!!!
Ok, I did a quick test but limp mode was still there.... after 2-3 minutes of cruising around.
I don't have my laptop with me, so no datalog, but i checked errors and I have:
P0102 (MAF error, should be ok because engine is running withiut MAF)
P0108 (MAP error, sensor circuit high..... could be the problem ??)
P0141 (O2 sensor number 2, shouldn't be an issue)
P0443 (Purge solenoid, the car haven't EVAP system, shouldn't be an issue I guess...)
P1514 (If I'm not wrong this should cause Limp Mode, right?..... but why I have this error?.... maybe because of no correlation between MAP and TPS ?)
C1278 (this is coming from ABS and should be consequence of P1514, right ?)
My question is:
Why I'm having P1514 ?
Should be caused by an uncorrect correlation between MAP and MAF..... but my MAF is off..... and tables C6101 and C6102 are maxed out respectively at 4095,9 and 4000
There are more tables correlated to this kind of problem ?
Are my consideration wrong is some way ?
Thanks guys, any help is very appreciated !!
Ok, will do in the next days !!!
Hi guys,
sorry for being so late, but I had no time to do it before.
Here a LOG of some cruising around with at the end the limp mode !!
Log_0073.efi
The car have a mild cam, 383 LS1 stroker engine and Harrop Hurricane Intake.
If I can delete this problem I can't tune the car which, I'm desperate !!!
Thanks for any kind of help !!!!
Forgot to mention that errors are the same even with new TPS and new MAP.
Of course P0102 means that MAF is disabled, can P1514 be consequence of P0108 ??
Really confused......
I will have a look when I get to my laptop
can't view the file from this PC
what injectors do you have ?
EFILive Tuner
Stock injectors, engine isn't already tuned....... I can't do it if I can solve the problem.
By the way the car is running smooth when criusing.
Nobody have found the way to completely delete this annoing limp mode ? I guess many people would be very happy !
Hahahaha.....
yes..... I'm so desperate..... I'm too desperate even to open the laptop !!
