Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: July 2017, Beta Release 4
    Default July 2017, Beta Release 4
    Download EFILive V7.5 (Note: Update to resolve Known Issue #4 below)
    Download EFILive V8
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.10 Build 328 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.5 Build 320 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.117 (Jun 23, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    When using the "Record All Diagnostics" option on FlashScan or AutoCal you must select the target controller by "selecting" a PID list so that the freeze frame PIDs can be correctly scaled/displayed. But any PID that is contained in that PID list will display its minimum/default value in the freeze frame data instead of its correct value.
    Workaround:
    Create a PID list with no PIDs selected for the target controller and select that PID list prior to performing the "Record All Diagnostics" option.
    Will be fixed in the next update.
    Issue #4:
    The V7 Tune Tool software no longer recognizes CMC custom operating system tune file and refuses to open them for editing.
    Workaround:
    Download the updated EFILive_Tune.zip attachment and extract the EFILive_Tune.exe into the EFILive V7.5 installation folder - overwrite the existing EFILive_Tune.exe file.
    Thank You!
    Currently in Manila to tune some cars and those Dam desoot mode options are turned on in all the e38/e67 cals.
    Senior Member auspeed's Avatar
    Jul 2010
    What is desoot & what impact does it have on the Vehicle?
    it fixes some stupid/retarded "feature" gm decided to put in most of the NA tunes.
    Basically 2 seconds into pe enrichment you get what can only be best described as a injector pulse freeze. You can't log it make the change to the PW, but you will see the car momentarily go leaner than commanded, before it richens up again.
    On a NA car you wont feel it too much, but on a boosted car if your still running closed loop & pe enrichment you will feel it depending on your enrichment strategy.
    Thanks for letting us know about that one Tre-Cool, it is an interesting 'feature' indeed.
    Junior Member Jedi_Jr's Avatar
    Jul 2010
    De-soot is an interesting read, and it seems to be less of an issue in PFI engines VS DFI engines. This is all referring to the B1220 and B1221 new settings in the E37, E38 and E67.
    http://www.sciencedirect.com/science...01679X15000432
    Aug 2009
    I would have let you know Ross , but you know , E38 is a bit of a swear word in the Myer's household :P
    Hope you've been well mate !
    Jul 2017
    I can't update my device, I do everything how in video below but my device show me error
    Nov 2005
    Quote Originally Posted by carlsonc857 View Post
    What error are you getting and at what step?
    Cindy
    Sent from my iPad using Tapatalk
    Quote Originally Posted by APS Luis View Post
    Na, just too much water under the bridge so I can't remember enough about the E38 when asked out of the blue. The T43 is the one we don't dare mention.
  1. April 2017, Beta Release 2
    Last Post: June 29th, 2017, 03:06 PM
  2. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
  3. July 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: September 5th, 2016, 03:18 PM
  4. EFILive July 18th Beta Release (CSP5)
    By GMPX in forum Software Updates and Installation Help
    Last Post: August 22nd, 2013, 02:18 AM
