Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Turbo tuning for the first time
    Jun 2018
    Thanks for the PM, I hit you up on your email.
    Looks good, as if from factory
    Jul 2003
    What sort of fuel is this? noticed you are definitely not going into PE that easily. Even then you are commanding .87L which is not correct for what I am sure you want to achieve. Your goal as a calibrator is that what you command is what you achieve. I would start with a MUCH flatter boost ve table. The way the airflow from VE calculation works, it takes into consideration the map that you are in. So its not a straight up airflow, only a a coefficient. So a much flatter curve will get you there faster.
    I would log less parameters. For instance, you are speed density, so you shouldn't log sae.maf. Keep the channels to 24 and it will log at 10Hz, which is decently good data.
    Hope I am not being captain obvious.
    i gave him some help and run down on how to set it up correctly. unfortunately it was a bit too late & we think the engine has broken a couple of ringlands. he was having issues with a bunch of different map sensors giving weird values on known configurations.
  1. First time Allison tuning questions
    By bmd2_colo in forum Allison 5 & 6 Speed
    Last Post: April 30th, 2014, 03:37 AM
  2. Noob First time tuning question
    By bercar in forum Gen III V8 Specific
    Last Post: July 24th, 2012, 07:25 AM
  3. Help!04 2500 6.0 turbo COS3 first time MAP tuning
    By Dv8td in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 7th, 2010, 06:49 AM
  4. First time tuning
    By spiderpat in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 11:10 AM
  5. Live Real Time Tuning?
    By Nox in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2005, 02:08 PM
