Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: EFILive Pre-Release 06
  1. #21
    Paul,
    Has the V2 analog logging error been fixed...?
  2. #22
    Paul,
    Yes, as far as I know.
  3. #23
    May 2010
    I want to know if the 2013 GMC trucks are supported now ?
    Any body ?!!!
    EFILive Tuner
  4. #24
    Nov 2005
    Default EFILive Pre-Release 06
    Any body ?!!!
    Specifically which trucks/engines? Gas or diesel?
    Cindy
  5. #25
    Any body ?!!!
    I think you had asked about these earlier, the 6.0L with the E78 ECM, the answer is the files are not in the pre-release, but Email support and we can send them to you.
  6. #26
    Glad to see things are progressing, eta for PR07? And then maybe a public release after that (barring any major issues)? Or is everything going to stay Pre Release until the V8 Scan tool is done?
  7. #27
    May 2010
    thanks a lot I will email support
    EFILive Tuner
  8. #28
    Jan 2011
    I am getting an $050B error if I try to revert my V2 or Autocals back to the latest public release firmware, even after programming a BBX configuration update with the V8 build 203 public release. Anyone else confirm this and can we get a fix - I shipped an Autocal out to a customer yesterday that I had reverted back to the public release firmware not realizing the script error is going to occur unless it is updated to pre-release 06. I tested this as well - I can go back to the pre-release firmware and BBX program it again with pre-release 06 and everything works again.
    Brian
  9. #29
    Jan 2011
    Quote Originally Posted by VTuner View Post
    Brian
    Here are some more details I have been able to confirm-
    I can update a V2 or Autocal firmware to the pre-release and as long as I have not written a specific BBX configuration , I can then revert the firmware back to the public release and program the BBX configuration using the public release and no $050B error occurs - so the firmware is not the problem, rather something else is not updating properly on the autocal that I can not erase (I tried formatting the data file and that did not help). Once you program a V2 or Autocal with a specific BBX configuration using the pre-release it is impossible to go back to the public firmware/software and re-program it with the same BBX configuration - ie, once you use the pre-release to BBX program tuning for an E78 you can not revert back to the public version and BBX reprogram the E78 cofiguration.
  10. #30
    Paul,
    Ok, thanks.
  1. EFILive Pre-Release 05
    Last Post: July 16th, 2013, 12:20 PM
