Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: Vortec Calc VET Auto Tune, Final Answer!
  1. #41
    For CALC.DAT you could use IAT or some blend of IAt and ECT (with IAT being dominant).
    I don't think EFILive have the time to revisit the Vortec (what you see is all they found back when)... do you want me to ask...?
    ( hmmm, this means it becomes difficult to do AutoVE )
    How does vehicle run with the Calc.VET corrected MAF and calculated VE...?
    ( notice I use the words "corrected" and "calculated" with specific semantics )
  2. #42
    Dec 2010
    I'm catching up to your specific!
    For now laymans terms.
    My tune was close, done the old fashion way with WB, math and smoothing, not a lot of Mods, just a sweet clean shop truck I bouhgt. I then applied this tutorial stuff, calculated data OL and with WB made corrections to VE, checked data and was good. Then went CL and did the same and there was not much even worth changing. This was for VE.
    Was working on MAF after that last post. Same thing, OL then CL, works well. MAF Freq was untouched before data today. After data it was spot on to 7000hz, from there to 9000hz needed correction. After correction data was spot on. I have not done anything SD/MAF disconnected.
    Without the B4901 table being there to confirm it's just a guess... but it is working as is, just as it should so I'm guessing the table is there and accurate.
    So AutoVE may be out for now, this PCM does have a back up VE table but it is half size of main VE. Not sure any more calc-pid work is needed for the GM.DYNxxx air stuff, we have a plan! I sure learned a lot about calc-pids! Reading the tutorials it tells you exactly what to do and in the end it works, but you never get an understanding of how and why! Man I am now trying to apply it to something else... still working on full understanding.
    Truck runs awesome!
  3. #43
    Dec 2010
    Heck yeah! Besides what I noted there are a few other things, I'll beta test.
    If I can find them I'm sure the pros could do better. Make this 98-00 vortec worthy of the EFI Live name! Want to really turn some heads? Lean Cruise!
    Look at all the dead ends in this forum? Look all over the net and it's the same answer, swap to 0411! Why? I just found all the issues and answers! Most Vortec builds are done well within the means of this PCM and the limits of the intake, it's a truck after all, not a race car!
  4. #44
    Id love to see a little more Vortec support, but I doubt EFILive will invest the dev time. Jesse at Wait4Me might be persuaded to look for more tables depending on what exactly we need.
    But Ross and Jesse know if they open this can o worms that Ill start bugging them for another P10 update...lol. I dont want to get banned from here!
  5. #45
    Dec 2010
    calc_pid low and high?
    Since we changed this it does not look right for low and high?
    Code:
      #Units             Low          High      Fmt  Expression
    *CLC-00-032
    factor             0             4         .0  "{GM.AFR_B}=14.20"
    *CLC-00-110
    factor             0.5           1.5       .4  "{EXT.WO2AFR1}/{GM.AFR_B}"
  6. #46
    The low and high are the chart/gauge min/max tick marks.
  7. #47
    Dec 2010
    calc_pid file is cool!
    Is there a known list of *CLC-xx-xxx numbers? I'd like to re-number these as specific to what's needed here.
  8. #48
    Dec 2010
    Nevermind, I see CLC in sae-genaric start at *CLC-00-900 so any below 900 would be OK...
  9. #49
    Dec 2010
    OK looking for some testers!
    Here's a calc-pid.txt file needed and a picture of PID selection. The calc_pid list has a few more then needed and so does PID selection, I'm still working on MAdisconnecteded because those PIDS do not exist on the Votec.
    Some of the calc PIDS are same as others, the ones that have been modified for the Vortec version have been given new *CLC numbers.
    All directions for all tutorials apply for what ever data your trying to get, read them and create your MAPS.
  10. #50
    Looks good.
    For CLC-00-033 (CALC.CL) I would make the low/high values something like 0/1 (full scale is whole chart) or 0/4 (full scale is lower 1/4 chart), -3/1 (full scale is upper 1/4 chart); and you can set the precision for this to .0 since you don't need decimal fraction digits (it's a true(1)/false(0) value).
  1. Auto VE or Calc VET or Auto Maf?!?!
    By Nver2loud in forum Gen III V8 Specific
    Last Post: October 23rd, 2012, 05:08 AM
  2. Cannot get the PID's for either Calc or Auto VE table
    By ippielb in forum Gen III V8 Specific
    Last Post: May 31st, 2011, 02:09 PM
  3. Replies: 1
    Last Post: October 24th, 2006, 06:54 AM
  4. More idle table questions (answer and win a smiley)
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 06:58 AM
  5. a few questions to answer...any help appreciated
    By The Alchemist in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2005, 10:52 PM
