Results 1 to 10 of 19
Thread: E92 GMC missing table
    Jan 2012
    Default E92 GMC missing table
    Greetings ,
    I just noticed that there's a missing table that keeps playing with timing on GMC pickups , I used to tune them with hptuners without any problems .
    It's related to humidity and it was labeled as " VCP humidity adder dry " in HPT , even though there are humidity spark and multiplier in efilive , none of them did the trick and I had to use HPT .
    Please add this table .
    Attached stock file .E92 GMC.ctz
    So there is a spark and multiplier already, what does the missing table do, add additional timing over the base humidity spark?
    Jan 2012
    No idea , but it adds additional timing to main spark table .
    The tables highlighted by green are the ones that available in efilive but the ones in red are the missing ones which have the major affect .
    Ok I pass it on to the guy mapping these, hopefully they are not too hard to locate and figure out.
    Jan 2012
    Hope so , thank you for your help .
    The question is why most cars aren't affected by those missing tables , like (CTS-V , corvette , camaro , etc ) ? I have only seen them doing work on trucks.
    Jan 2012
    Any updates on this ?
    Jan 2012
    I'm still having this problem and the latest update didn't solve it , the tables are still missing .
    May 2010
    Quote Originally Posted by Eng.LSX View Post
    I noticed the same thing in 2015+ truck only
    Not in Camaro nor Corvettes
    The timing will be 4-5 degrees less than the high octan table after flashing the ECM and never found the table which cause this
    EFILive Tuner
    Jan 2012
    That what I was getting first but then I've narrowed it down to 2 degrees less the the main spark which lead me to the missing table that I found using hptuners , which related to humidity .
    And yes it's only with the trucks , too bad HPT is way ahead now a days .
    May 2010
    The problem is the spark will go back to the high Octane after nearlly 20 min of driving
    And yes I tried adjusting the octane scaller without luck
    So there is a table thats a time dependant which will cause the timing to be decreased for arround 20 mins after ECM reflash
    EFILive Tuner
  1. Is there any table to compensate for bigger TB in E92 ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 21st, 2016, 09:20 PM
  2. 2011 gmc sierra 5.3 e38 superchargered which VVE table???
    By Pela in forum E37, E38 & E67 PFI ECM's
    Last Post: February 1st, 2016, 05:24 AM
  3. 14 silverado 5.3 E92 Table B8305
    By efilivesteven in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 17th, 2015, 11:29 AM
  4. Missing table?
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 9th, 2009, 03:39 PM
  5. Missing Table B3647 after full reflash
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 8th, 2005, 04:09 AM
