Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: AEM X-Series Wideband - Serial
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default AEM X-Series Wideband - Serial
    Hi all,
    I'm getting started back up after a few years out of the game. I got a new AEM x-series wideband installed last week. I used to tune with an LC-1 but it died a few years ago. The new wideband is working but I can't get the V2 to see the sensor. I believe I have it wired correctly, I have verified that my ground and signal output go to pins 5&1 respectively on the Flashscan V2 RJ-11. The V2's 2nd light (serial coms) doesn't light up. I figured out how to cycle through different wideband options on the V2 by pushing the backspace button. The wideband doesn't show up on any of them. I've been out of the game too long, is there something else I have to do to the V2?
    I wanted to start a new thread because the other one is focused on CAN communications. Working on an LS1B controller here. I feel old since everyone is playing with the new stuff now
    *Full disclosure*
    I originally bought the 30-0333 kit but should have bought the 30-0300. I depinned AEM's 3&4 pin and reused one of the pins for my serial out (pin 5). I'm pretty certain I didn't mess that up... but you never know...
Name:	AEM pinout.JPG
    Last edited by Gregs; February 11th, 2017 at 09:54 AM. Reason: Forgot to attach graphic
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Which signal are you using (Tx or Rx)...?
    ~Moderator~
    Junior Member spedracr93's Avatar
    Jun 2016
    Quote Originally Posted by Gregs View Post
    I'm having a similar issue with the exact same sensor. I bought this with the desire to record serial data only to be disappointed when I opened the box and found that there weren't any wires for outputs beyond the CAN. I bought some contacts and 26 ga. wire and installed a wire at Pin 5 of the UEGO plug for serial output. I connected that wire to Pin 5 of a 6P6C connector while Pin 2 of the UEGO connected to both Pin 2 of the 6P6C and directly to a chassis ground.
    Like you, my sensor is working fine on the display but I cannot get the V2 to read the signal.
    I noticed you said you were hooked to 5 & 1 on the V2, but I have read it should be 5 & 2. I wonder if that's not your issue. I still don't know what my issue is...
    Here's a crude representation of how mine is wired...
Name:	AEM 30-0333 Serial.png
    Sep 2008
    ~Moderator~
    AEM Pin #5 (Serial/RS-232 Output) to Flashscan V2 pin #1 (RX)
    Stock for now
    Sep 2008
    Quote Originally Posted by spedracr93 View Post
    Nice diagram! I'm at work and my connector is at home but I think my ground was white on the connector going into the V2. See attached graphic I stole from the forum, I took that diagram as looking into the V2, so you would have to make sure you weren't looking at the connector backwards, might want to double check that? See my reply to Joecar, I have my AEM output going to V2 RX (pin #1). Maybe I'm thinking of this backwards?
Name:	V2 rj-11.jpg
    Last edited by Gregs; February 13th, 2017 at 05:47 AM. Reason: spelling correction
    Stock for now
    Look at this:
    serial-port-cable-that-goes-to-v2~post#15
    Summarizing from mr.prick's link (that's a very good link, thanks):
    There are two types of serial equipment:
    - DTE (data terminal equipment) e.g. computers, printers.
    - DCE (data communications equipment) e.g. modems, wideband, FlashScanV2.
    DCE devices can connect directly to DTE devices without Tx/Rx crossover.
    Tx is the device's serial output (on which it sends out serial data).
    Rx is the device's serial input (on which it receives in serial data).
    Wideband and V2 are both DCE (transmit = Rx, receive = Tx)...
    so somewhere in between them this has to be done (this is what the null modem adapter does, crosses Rx and Tx):
    wb.Rx ---> V2.Tx
    wb.Tx <--- V2.Rx
    (see post #19 below)
    See the attached diagram (I added some labels).
    Try connecting to V2's Tx pin.
    Sep 2008
    Look at this:
    Thanks, I'll try this tonight
    Stock for now
    Sep 2008
    No luck, I switched AEM output to V2 pin 2 (tx). V2 still doesn't read the wideband.
    Stock for now
    Yeah i purchased a bunch of new units and had Dr Mike change the firmware to support a faster transmit speed and give me can support for efilive & all 3 of the guages wont work for serial. so I'm thinking something is broken on that firmware for that model.
    I can swap in another guage and serial comms works, so i know it's not the cable.
    Jun 2016
Name:	V2 rj-11.jpg
    Yea, I'm not sure. I wired it up from this: https://forum.efilive.com/showthread...ging-afr/page2
    OP said he had success going to 2 and 5, and then the last post from joecar more clearly states what should be the pinout.
    Is there a way to verify serial output other than through the V2. I can read a voltage output on the signal wire, but obviously that doesn't correlate to the transmission like the analog output does. It varied from 0.48 to 0.51 V changing similarly to the rate of the AFR output on the gauge.
  1. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 08:58 AM
  2. AEM wideband to FlashScan V2
    By T34418L31 in forum FlashScan V2
    Last Post: May 14th, 2015, 12:22 AM
  3. Aem failsafe gauge not serial
    By Slowrc in forum General
    Last Post: August 12th, 2014, 12:23 PM
  4. AEM Wideband Serial Hook-up -
    By RamAir in forum Petrol / Gas
    Last Post: May 29th, 2013, 11:03 AM
  5. AEM wideband 02 support?
    By PRAY in forum Petrol / Gas
    Last Post: October 7th, 2012, 10:28 PM
