Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 54
Thread: 2018 6.7 C&C Tuning Issues
  1. #41
    J1939 bus still has digital signature verification on a flash, it gets around the OBD-II port security gateway but not the main issue.
  2. #42
    Jan 2009
    I see MM3 and Ezy have 2018 flashing support, has there been any further advancement with you guys?
    Thanks so much
    Mitch
  3. #43
    Nov 2005
    Hey Mitch,
    11 new OS's were added in the November public release. http://www.efilive.com/latest/cat/do...public-release
    Cindy
    Sent from my iPad using Tapatalk
  4. #44
    Feb 2012
    Cindy, will you guys be offering a solution to turn off RSA with the HD V2 via the J1939 port for the 2018 CM2350B? I assume the 2018 RSA can only be turned off that way, similar to the 2013-2017 correct?
    Sam
  5. #45
    Quote Originally Posted by Mitco39 View Post
    We won't be able to flash through the OBD-II port because of the gateway module (not sure if they can). CSP OS's are also completed for the 2018's.
    Quote Originally Posted by 30 RUM View Post
    At this stage it is not in the pipleline, I know it makes sense to given the HD V2 is talking J1939 but it really isn't a simple task.
    Keep your ears open though because there is a better solution coming that does not involve J1939 (it is not our project), I just know of it and apparently it works just as good.
    FYI, the 2018 ECM is a CM2350F, it is slightly different which is why even stock tunes from 2013 - 2017 will not flash in to them.
  6. #46
    Feb 2012
    Thanks for the reply,
    Will the CM2350F take a CM2350B file after the RSA has been switched off then? Flashing Via bench harness.
  7. #47
    Jan 2009
  8. #48
    I would say so, we've been testing the CSP operation of the 2018 in a 'B' ECM, but I don't know if there is subtle hardware differences that on a vehicle might be an issue.
  9. #49
    Dec 2013
    Fantastic news guys!
  10. #50
    Apr 2015
    Quote Originally Posted by SASDakota View Post
    CM2350F, because "why not" change the private key you sign files with on CM2350B one year before you move to CM2450. Sigh. Really odd choice considering the key has been static from 13-17. Who knows.
  1. 2018 Zl1 Camaro A10 support?
    By ringram in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 28th, 2017, 09:49 AM
  2. Replies: 3
    Last Post: August 11th, 2017, 12:39 PM
  3. Starting issues? B0102 & B5909
    By onegonewild in forum Gen III V8 Specific
    Last Post: January 1st, 2010, 07:08 AM
  4. ECM, TCM, PCM & BCM Issues Who's the Expert
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2008, 01:30 PM
  5. Latency issues with 98Fbody & V2
    By Doc in forum Gen III V8 Specific
    Last Post: August 12th, 2007, 03:01 PM
